GoPro users (on bike, cycle, car, helmet whatever)
t121anf
PostPosted: 13:15 - 02 Mar 2015    Post subject: GoPro users (on bike, cycle, car, helmet whatever) Reply with quote
(mods feel free to move to appropriate forum if required)
Ok I'm not sure where to put this, could be here, geek zone, random, bike vids etc
Recently bought a GoPro 4 Silver (you may recall my post in here), it's arrived, memory card has arrived, now I need/would like to use it.
It only came with the standard mounts, stickers and 3 point arm iirc, not a lot for all it's potential.
So i've been searching and came across the likes of
https://www.ebay.co.uk/itm/271513065258?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Can anyone recommend any similar, or better value for money accessory packs?
Or is the one linked overkill? I'll probably not use half of it but then buying some of the bits separately mounts up to the same cost as all that lot.
Is the suction mount from GoPro any better than generic ones?
flikers
PostPosted: 13:21 - 02 Mar 2015    Post subject: Reply with quote
Amazon do some good value kits.
https://www.amazon.co.uk/Accessory-Ultimate-Combo-accessories-Cameras/dp/B00JBT6F3W/ref=sr_1_2?s=photo&ie=UTF8&qid=1425298835&sr=1-2&keywords=gopro+mounts
I have a generic suction mount and mounted it to my car whilst in Germany. Held on at 110MPH.
Snorty
PostPosted: 17:19 - 02 Mar 2015    Post subject: Reply with quote
The GoPro suction cup is good for 160 (indicated) I can confirm. Says tested at 150+.
I tend to tie it to something as well... Just in case.
I mount it to my helmet, my tank or my fairings with that. Bang on every time. We put it on my mate's car sometimes too.
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xfp1/t31.0-8/906335_10154292245325332_2623501501672437320_o.jpg
https://scontent-lhr.xx.fbcdn.net/hphotos-xpf1/t31.0-8/10006014_10154100714160332_9081975299729828340_o.jpg
Putting it on your helmet can cause some heavy pulling from the wind.
t121anf
PostPosted: 17:42 - 02 Mar 2015    Post subject: Reply with quote
Is that suction cupped to your fairing?
The flex in the plastic not causing any problems?
Might get a proper suction mount and cheap other stuff for now.
BravoCharlie
PostPosted: 17:43 - 02 Mar 2015    Post subject: Reply with quote
I've got a hero 2 i've had a couple years but rarely had the chance to use. i've found that the clip mounts work well but i put one on my helmet and it dragged a lot.
The suction cup is pretty impressive though, and i'll likely use it more in the summer this year.
Current: Kawasaki ZL600 Eliminator
Past: Suzuki GZ125, Kawasaki GT550, Kawasaki GPX600R, Honda vrx400,Kawasaki Zephyr 750, Suzuki SV650 K5
Dream as if you'll live forever, live as if you'll die today.
Snorty
PostPosted: 19:18 - 02 Mar 2015    Post subject: Reply with quote
Suction cupped to the side yeah (avoiding any vinyl overlap).
Better than the sticky pads if you're not bothered about it sticking out a little further - you can re use it over and over.
image riot
PostPosted: 19:30 - 02 Mar 2015    Post subject: Reply with quote
Agree. The suction cup is almost impossible to remove when attached. Proven on German autobahns Very Happy
https://www.youtube.com/watch?v=FgjdYQG6u5Q
GSXR750 > GSXR1100 > ZX9R > CBR900RRP >CBR929RR>K1200S
Tungtvann
PostPosted: 19:34 - 02 Mar 2015    Post subject: Reply with quote
Mine fell of the back of my bike. Never saw it again.
Snorty
PostPosted: 19:38 - 02 Mar 2015    Post subject: Reply with quote
I always tether the camera as a secondary precaution, probably batter my fairings but I trust the suction cup.
image riot
PostPosted: 19:46 - 02 Mar 2015    Post subject: Reply with quote
https://i5.photobucket.com/albums/y183/cruxiform/Mobile%20Uploads/20140802_141822.jpg
It's worth double checking the suction mount, this is what happens when you don't. It got run over by a lorry. I now double check everytime I attach it to the bike. Saying that I still don't use a tether.
Northern Monkey
PostPosted: 19:56 - 02 Mar 2015    Post subject: Reply with quote
L shaped arm then stick it to the side of your hat. I mount mine like this for commuting. Was about a fiver on ebay
https://img.photobucket.com/albums/v284/geoffhill/537A9A26-E645-4E53-82A8-03AC692507F0_zpsfbzny31i.jpg
Tungtvann
PostPosted: 19:58 - 02 Mar 2015    Post subject: Reply with quote
Yeah, it was my fault rather than the suction cup. The surface I put it on had a slight curve and I didn't double check it was on properly before I rode off. On a decent surface, they're very secure.
image riot
PostPosted: 20:18 - 02 Mar 2015    Post subject: Reply with quote
Don't sweat it mate, I did the same. I felt like a proper prick when it flew off.
t121anf
PostPosted: 21:41 - 02 Mar 2015    Post subject: Reply with quote
Tethering will be used.
Bought the Amazon kit as its next day delivery for me, if the suction cup is poor I'll get a proper one.
For shots from the side of a car would you mount of the body work or glass with long bars?
Peirre oBollox
PostPosted: 22:15 - 02 Mar 2015    Post subject: Reply with quote
For tethering consider using some nylon coated stainless steel sea fishing lures, you can fix the loop through the camera case base screw, leaving a wire clip to attach to or loop round a solid object, or helmet buckle. So if the GP brackets snap the tether is connected to the nearest point to the camera
I use 12"/18" "AFW brand" bleeding leaders with 30lbs breaking strain that I got on eBay for a few quid
binge
Emo Kiddy
PostPosted: 22:58 - 02 Mar 2015    Post subject: Reply with quote
Mine, suction mounted to the windscreen of the SJ. Gets battered off tree branches and everything. Hangs in there every time!
And if it does come off, I have it tied up with a landyard to something solid on the truck.
https://scontent-lhr.xx.fbcdn.net/hphotos-xpa1/v/t1.0-9/1618460_10153130203385606_4569396376750422968_n.jpg?oh=62943e53f0655733aac3b89522c39973&oe=558663A1
And some other mounting locations:
https://scontent-lhr.xx.fbcdn.net/hphotos-xpf1/v/l/t1.0-9/11017688_10153130565980606_2595378230726262146_n.jpg?oh=b81f3d08aa616573943e878f3485bee7&oe=557FF871
C1REX
PostPosted: 01:56 - 03 Mar 2015    Post subject: Reply with quote
RAM mount on handle bars for me. I occasionally turn it the other way to have some footage of the rider.
MCForum meetup - One of the biggest motorcycle clubs in UK
t121anf
PostPosted: 11:41 - 03 Mar 2015    Post subject: Reply with quote
A big bundle of stuff has arrived (loving Amazon Prime at the mo), suction mount seems ok didn't pull off my desk though one of the screws doesn't feel like it gets really tight, something to work on tonight.
Thanks for the recommendation.
Snowdonia Rider
PostPosted: 15:11 - 03 Mar 2015    Post subject: Reply with quote
Everytime I attach it to the bike.
Wow it still works in that condition? Wink
dolly3900
PostPosted: 12:52 - 04 Mar 2015    Post subject: Reply with quote
Got one of these thingies with my bullet camera.
Clamps onto the end of the bars quite nicely, good stable platform for smooth footage too, shame the camera is a bit of a pig, but then again, for £30 off of e-bay, what can you expect.
https://i823.photobucket.com/albums/zz157/mikeallen3lly3900/IMAG0983_zpsaec8msy6.jpg
Standard fittings and threads on it, so when i get round to getting a decent camera, it'll fit on nicely.
Mike
(Sorry for the bad pic, but you get the idea)
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
Snowdonia Rider
PostPosted: 17:47 - 04 Mar 2015    Post subject: Reply with quote
Mike
Is there a way to aim those? Or is it a case of record, view and amend position?
DoohanFan
PostPosted: 17:58 - 04 Mar 2015    Post subject: Reply with quote
https://www.facebook.com/photo.php?fbid=10152662452066611&l=6a3e72a99c
Made this to hold mine. Bolts straight to the damper cover and films through the screen.
Bike history: GP100, NS125R ( wrote off ) , RG125 FUN, VFR400 NC30 ( nicked ). VFR400NC30 (race tuned), R6 (parts robbed ), CBR929 RRY, CBR1000 RR-4
t121anf
PostPosted: 21:00 - 04 Mar 2015    Post subject: Reply with quote
What's the white thing?
Tungtvann
PostPosted: 22:04 - 04 Mar 2015    Post subject: Reply with quote
Rubber damper.
rideslikean00...
PostPosted: 22:09 - 04 Mar 2015    Post subject: Reply with quote
Would it be feasible to mount a GoPro to the centre of the bars? To me this seems the most logical place to put it, with the lens just poking above the front screen so when you watch the footage it's like you're on the bike with your chin over the tank. I'm assuming dampening would be needed if it's possible.
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
The last post was made 11 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 132.28 Kb
