| Djaniero |
 Djaniero Two Stroke Sniffer
| Polarbear |
 Polarbear Super Spammer
 Posted: 09:41 - 06 Mar 2015 Post subject: |
Either buy a new bulb or use a multi meter.
It might well be the operating switch, especially the one down on the rear brake if that is not adjusted properly.
Infact, get a cheap multi meter and set it on DC volts
Then do things logically.
1: check bulb (including contact areas)
2: check fuse (if it has a seperate one)
3: Check front/back brake switch
Other than a broken wire there isn't much else to go wrong. ____________________ Victory Cross Country American tractor. |
| Djaniero |
 Posted: 10:00 - 06 Mar 2015 Post subject: |
Thanks mate. I've got a Halfrauds Multimeter at home.....only used it a handful of times though as electrics isnt one of my strong points  |
| Polarbear |
| andyscooter |
 andyscooter World Chat Champion
 Posted: 10:10 - 06 Mar 2015 Post subject: |
if it was the bulb blown it wouldn't work at all would it
im guessing faulty switch
does it work off front brake lever as well though  ____________________ gilera runner vxr200 (chavped)
if its spelt wrong its my fat fingers and daft auto correct on my tablet |
| Recluso |
 Recluso Brolly Dolly
| BillyJ |
 BillyJ Nearly there...
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:44 - 06 Mar 2015 Post subject: |
If you put your location in your profile then a friendly BCFer might be able to drop by, suck their teeth and say "Oh, that'll cost you." ____________________ Biking is 1/20th as dangerous as horse riding.
| Polarbear |
 Posted: 11:27 - 06 Mar 2015 Post subject: |
If it was one brake switch it would work on the other ie, if the back switch was faulty the front would work or vice versa. If it works with neither it must be either the supply before it splits (Fuse?) or the earth return from the bulb.
I'm presuming you have both front and back brake light switches I did have a suzuki GT500 that was built with only one on the back brake.
I agree it's unlikely to be the bulb, but test it/change it anyway. It is the first and easiest test to do.
If it is a double filament bulb and the other light works OK, you can ignore the earth/return line as it will be common. ____________________ Victory Cross Country American tractor. |
| thx1138 |
 thx1138 World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:51 - 06 Mar 2015 Post subject: |
| Djaniero |
 Posted: 13:56 - 06 Mar 2015 Post subject: |
| weasley |
 weasley World Chat Champion
The last post was made 11 years, 204 days ago. Instead of replying here, would creating a new thread be more useful? |
