Brake Light Not Working
Djaniero
PostPosted: 09:32 - 06 Mar 2015    Post subject: Brake Light Not Working Reply with quote
So I finally got my cherry popped and took my bike out for the first time last night. It was a bit daunting as many people warned me not to ride at night due to various dangers. But I suited up with my gear, put my high vis on and off I went....to say that I was grinning from ear to ear was understatement.....I only have a lil aprila mx 125...but it was a joy to ride. I should have got into biking years ago!
Anywhooo I think you get the point lol
When I bought my bike the previous owner said the brake light was faulty. Sometimes it worked, sometimes it didn't. Anyway, last night was working fine when I set off, but about 15mins into my journey it stopped working - Mate was driving behind be luckily and told me.
Is there anyway to test whether its the bulb or a break in the circuit?
Thanks
PostPosted: 09:41 - 06 Mar 2015    Post subject: Reply with quote
Either buy a new bulb or use a multi meter.
It might well be the operating switch, especially the one down on the rear brake if that is not adjusted properly.
Infact, get a cheap multi meter and set it on DC volts Thumbs Up
Then do things logically.
1: check bulb (including contact areas)
2: check fuse (if it has a seperate one)
3: Check front/back brake switch
Other than a broken wire there isn't much else to go wrong.
Djaniero
PostPosted: 10:00 - 06 Mar 2015    Post subject: Reply with quote
Thanks mate. I've got a Halfrauds Multimeter at home.....only used it a handful of times though as electrics isnt one of my strong points Embarassed
PostPosted: 10:06 - 06 Mar 2015    Post subject: Reply with quote
So set it on DC volts - 1st level above 12v, probably 20v
then check by having someone operate the brake lever while you check between power wire and earth for voltage.
To check the bulb, set multimeter on Ohms or continuity and connect to bulb contacts. Be aware it might be a twin filament bulb.
andyscooter
PostPosted: 10:10 - 06 Mar 2015    Post subject: Reply with quote
if it was the bulb blown it wouldn't work at all would it
im guessing faulty switch
does it work off front brake lever as well though Mad
Recluso
PostPosted: 10:17 - 06 Mar 2015    Post subject: Reply with quote
Check the connection in the brake lever? Might be some water in there causing it to intermittently come on and off.
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
BillyJ
PostPosted: 10:36 - 06 Mar 2015    Post subject: Reply with quote
The switches are often a weak point, I had 2 fail on my CBR 125
You should always have a spare bulb to test with anyway by I would start by looking at the switch by the brake lever especially if it is an intermittent problem.
Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser"
PostPosted: 10:44 - 06 Mar 2015    Post subject: Reply with quote
If you put your location in your profile then a friendly BCFer might be able to drop by, suck their teeth and say "Oh, that'll cost you."
PostPosted: 11:27 - 06 Mar 2015    Post subject: Reply with quote
If it was one brake switch it would work on the other ie, if the back switch was faulty the front would work or vice versa. If it works with neither it must be either the supply before it splits (Fuse?) or the earth return from the bulb.
I'm presuming you have both front and back brake light switches Laughing I did have a suzuki GT500 that was built with only one on the back brake.
I agree it's unlikely to be the bulb, but test it/change it anyway. It is the first and easiest test to do.
If it is a double filament bulb and the other light works OK, you can ignore the earth/return line as it will be common.
thx1138
PostPosted: 11:53 - 06 Mar 2015    Post subject: Reply with quote
meh, just forget it until the day before the MOT and then run around panicking.
PostPosted: 12:51 - 06 Mar 2015    Post subject: Reply with quote
I finally found and fixed the erratic short in my indicators 200 yards from the MOT station. Thumbs UpWinkThumbs Up
Brake lights though, I kind of like them to be working.
Djaniero
PostPosted: 13:56 - 06 Mar 2015    Post subject: Reply with quote
Good point, as long as I don't get stuck up by any dodgy members Laughing
I'm based in Manchester.
Unsure whether I have front and rear switches Embarassed Rolling Eyes . But I'll try my best to check the bulbs and test the circuit etc with a multimeter.
weasley
PostPosted: 14:18 - 06 Mar 2015    Post subject: Reply with quote
You will have, so it is worth trying each one separately and seeing if the light works with either of them.
The rear switch is, I think, the small cylinder on the back of the rear brake lever assembly - I guess it's a hydraulic pressure switch.
The front switch will be screwed on under the lever somewhere - it'll be the thing that makes a small 'click' sound when you first pull the lever.
The last post was made 11 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 78.14 Kb
