What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 111, 112, 113 ... 407, 408, 409  Next
Pigeon
PostPosted: 00:18 - 08 Mar 2015    Post subject: Reply with quote
RhynoCZ wrote:
SQL wrote:
Refurbed rear caliper, what a utter cunt Mr Suzuki was designing that rear caliper.
You do realize, that Suzuki just picked that caliper from a catalogue, right? Possibly Nissin, could be a Tokico. Laughing
Tokico probably. Same as on Bandit and Hayabusa (some models/years). I quite like it as it has some grunt. Bleed nipple on wheel side is a bit annoying though.
https://i1329.photobucket.com/albums/w559/pigeon35/150228%20-%20SV%20Brakes/20150301_142906.resized_zps3ft2xkkw.jpg
SQL
PostPosted: 00:46 - 08 Mar 2015    Post subject: Reply with quote
Makes my eyes burn just seeing it again
ws4936
PostPosted: 01:32 - 08 Mar 2015    Post subject: Reply with quote
8 pots on my front wheel, consider yourself lucky.
If everything seems under control, you're just not going fast enough.
lozzypop1
Certified MILF!
PostPosted: 11:11 - 08 Mar 2015    Post subject: Reply with quote
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/s720x720/11000158_490080951131182_3864126839772450104_n.jpg?oh=1d786645860e48dbfef9dfa0fa372c10&oe=557486C5&__gda__=1435531253_e7e1457bfe9393ac9a24318531d5cda6
https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/s720x720/11043116_490081054464505_1751145513282182516_n.jpg?oh=3e7e1fadeb05abc0d0f20258d7e4c462&oe=5590F171&__gda__=1434420527_caeebf0ddc5777e26b44d24e1cedad15
Eddie Hitler
PostPosted: 13:35 - 08 Mar 2015    Post subject: Reply with quote
Quick clean. Fixed a few bits that needed sorting. Spotted this.
https://i.imgur.com/DQFaXZol.jpg
Islander
PostPosted: 13:49 - 08 Mar 2015    Post subject: Reply with quote
Blimey Shocked
What do you reckon caused that?
Eddie Hitler
PostPosted: 13:57 - 08 Mar 2015    Post subject: Reply with quote
Islander wrote:
Blimey Shocked
I noticed the other day some odd clunks from the bottom of the bike when I accelerated from a 30mph to a 60mph zone. In some ways it's a relief as I thought the clutch had dropped some bearings or whatnot (this has the usual clutch grab associated with VTRs - although the fluids haven't been changed in years, a job for tomorrow). Did change the engine oil the day after I got it, which reminds me, I also need a new oil filter.
Going to have to repair it with a split link for now until payday, then it'll get replaced with a new DID set.
Carvel
PostPosted: 14:10 - 08 Mar 2015    Post subject: Reply with quote
Yeeeeeaaahhh I wouldn't be using that till it had a new chain on it.
What caused it?
Doomsnite
PostPosted: 19:57 - 08 Mar 2015    Post subject: Reply with quote
Sprayed the rusty bottom yoke and headlight bracket with hammerite black. Chuffed how it came out!
https://img.photobucket.com/albums/v622/TOOMZ/A6F7679D-1A16-4AFF-B549-712144FE8E98.jpg
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
bikertomm
PostPosted: 20:11 - 08 Mar 2015    Post subject: Reply with quote
The fuck did you use on that.
How long?
Thumbs Up Karma
Islander
PostPosted: 20:46 - 08 Mar 2015    Post subject: Reply with quote
It's an impressive bit of damage that's for sure.
A split link and a bit of sympathetic throttle use should get you through. Thumbs Up
Musketeer
PostPosted: 21:01 - 08 Mar 2015    Post subject: Reply with quote
https://i37.photobucket.com/albums/e85/motorcyclesJZ/CBR1000RR/stompgrip_zps3nfifaaj.jpg
PostPosted: 21:23 - 08 Mar 2015    Post subject: Reply with quote
Fitted a baffle in the Enfield exhaust.
The noise has declined from "roguish" to "caddish", which is where I think I prefer it.
rideslikean00...
PostPosted: 22:20 - 08 Mar 2015    Post subject: Reply with quote
What I have done to the Fazer today? My standard end of week quick maintenance -
  • Check TPs, all good (new tyres are bedding in well)
  • WD40 on main key/in ignition to stop it seizing (common problem on all the Yamaha bikes I've owned)
  • Check kickstand (all good, hasn't seized, no WD40 needed)
  • Lubricate all contact point on gear lever/assy (Yamaha boxes are clunky at low speeds especially on 1st to 2nd and back, this helps)
  • Lubricate chain rollers/links (using Castrol Racing, might go back to Yamalube as it seems to last longer)
  • Quick clean of fairing/screen/mirrors with wipes to keep it looking good (it'll get a proper clean when it's serviced next week)
I'm thinking of moving to an oil change every 3K as a kind of interim service since I ride in all weathers, probably help engine longevity. Then onto changing filters etc myself so I'm not relying on the dealership to do all but the basics.
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
Pigeon
PostPosted: 01:17 - 09 Mar 2015    Post subject: Reply with quote
Supermoto_Fan wrote:
I've just put those on my SV - finding them superb.
What tyres did you have previously?
When I got PR4's on the ST it was a huge difference. Granted I've only done 50 miles on them on the SV, but my enthusiasm isn't quite as orgasmic as on the ST.
I had 6 year old near 1mm BT021's and can't really feel much difference in terms of confidence. The BT's were a liability in the wet, but that's to be expected with 1mm tread.
With new rubber, the SV seems harder to initiate the change of direction AND is now quite twitchy. By that I mean the slightest input on the bars, or weight shift and it's changing direction mid-corner.
So in short, harder to initiate turn, once in turn it's little lively unless I'm super smooth. Will wait and see what it's like after 200 miles or so.
https://i1329.photobucket.com/albums/w559/pigeon35/150305%20-%20SV%20Tyres/20150307_104249.resized_zps7e3ar0wb.jpg
me wrote:
Going for a bimble tomorrow. Fingers crossed it's quieter than the stubby, but louder than stock.
Happy to report that the new can is quieter than the stubby, but louder than stock. It's quite lovely Smile
I'm going to miss the violence of the stubby when out on the charge (as chargey as 60bhp can be). But won't miss the way it shattered windows and set off every car alarm in a 5 mile radius.
Speaking of which, anyone want to buy an end can? Smile
Will put an add up later.
Supermoto_Fan
PostPosted: 08:17 - 09 Mar 2015    Post subject: Reply with quote
Conti motions. Neutral
I originally had a pair fitted not long after I bought the bike because they were cheap, £170 fitted opposed to £250. I actually thought they was okay so fitted the same again, almost got rid of my chickenstrips on them come the summer months, did commuting and trips away but I knew that as the second pair were coming to the end I should treat myself and see what all the hype was about - it could only help such an old bike.
300 miles in, pressures to manuals 33/36 and loving them.
Check your pressures, don't suppose you checked your Cush rubbers and bearings Etc? Are they balanced?
UncleFester
PostPosted: 10:02 - 09 Mar 2015    Post subject: Reply with quote
Removed the baffle and shivered my way to work at 6am - haven't arrived with a grin this big in months.
Just about on the bearable side of frozen.
2017 Z1000SX
Fisty
PostPosted: 10:27 - 09 Mar 2015    Post subject: Reply with quote
Shoulda bought a TL.
Fatter and faster than Fret
Snowdonia Rider
PostPosted: 14:20 - 09 Mar 2015    Post subject: Reply with quote
Pigeon wrote:
haroman666 wrote:
Massive difference. If you've got aged factory lines with old fluid then it will transform your brakes. Perhaps less so on more modern bikes but my 14 year old factory lines were probably past their use by date.
I was in a similar boat to Haroman, brake lines were 14-15 years old and had loads of cracks (although no leaks).
But the front brakes on my SV were not good, just didn't have any power (regardless of refreshing fluid and bleeding). So I decided the replace the lines when changing the pads.
However, I can't say exactly how much improvement is due to the braided lines because I replaced the 70% worn organic pads with new sintered pads. I also replaced brake pistons and seals. So cumulatively, it's a big improvement.
Been using the SV all week, but only clocked up 50 miles, however the pads are getting better each ride. There is almost enough power and bite to two finger brake which was impossible with what I had before.
Cheers guys. I renewed the brake fluid on my GSX600 a few weeks ago and although there is a slight improvement the brake lever might still as well be made of a cheese string. Judging by the bikes history I think the brake lines must be at least 11 years old, if not the originals so time for a change me thinks in time for the nicer weather Thumbs Up
wodge
PostPosted: 17:23 - 09 Mar 2015    Post subject: Reply with quote
MOT'd Yammy RXS100... It's first mot since it's rebuild, its first mot on dvsa records. My first bike project.
No advisories, no problems to or from the test center.. Well chuffed.
Hello fairweather motorcycling.. Smile
-Matt-
PostPosted: 18:26 - 09 Mar 2015    Post subject: Reply with quote
Kriega US20 arrived - decided i'd had enough of messing around with drypacks, bungee's and cable ties everytime I go on a long trip.
Fitted the straps to the rear seat after about an hour of messing around trying to find somewhere decent to get them attached to Neutral ended up having to use tweezers to get the strap up through a tiny gap in the frame Laughing
All fitted in the end and really impressed with how easy it is to get on and off. Just big enough for a sleeping bag which i'd strap on top of it anyway so plenty of space for what i'm planning to use it for Thumbs Up
https://i58.tinypic.com/sbmq7d.jpg
Inb4 dropped on the motorway
Musketeer
PostPosted: 18:36 - 09 Mar 2015    Post subject: Reply with quote
Will it fit Fireblade? I've got Oxford panniers but they won't fit bikes with under-seat exhausts.
-Matt-
PostPosted: 18:38 - 09 Mar 2015    Post subject: Reply with quote
Not 100% sure; Aff's used the bigger US30 on his blade without any problems. Worse case I expect you would just need to drill some holes in the pillion-seat area somewhere to get the straps around, but you can probably find something Thumbs Up They seem to be mainly marketed at sportsbikes so i'd be suprised if it doesn't.
I'll grab some pictures of the straps fitted on mine tomorrow.
If you do get one, run a quote on thebikeinsurer and you'll get a 15% discount code, then buy through quidco at getgeared.com; knocks about £20 off Thumbs Up
Flatbadger
PostPosted: 19:59 - 09 Mar 2015    Post subject: Reply with quote
MOT passed with advisory that front brake is grabbing slightly - hopefully I can replace the pads myself. Now for the extortionate £17 road tax renewal Mad Mr. Green
You're in ISIS
Pigeon
PostPosted: 20:10 - 09 Mar 2015    Post subject: Reply with quote
I tend to run the pressures a bit over book as it's usually felt better, but I think your right, 33/36 was definitely better today. Cheers dude Thumbs Up
I balanced the wheels and checked the bearings + cush rubbers, all was ok (after adding 25-30g per wheel). Think tyre pressures needed to be as per OEM.
The last post was made 11 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 112 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 138.29 Kb
