RUST INSIDE FUEL TANK
rednog
PostPosted: 14:55 - 16 Mar 2015    Post subject: RUST INSIDE FUEL TANK Reply with quote
Can anyone advise me about combating rust inside a S/H fuel tank for an EN 500? I've sluiced it through comprehensively with paraffin for some now, and there are still bits of rust in the bucket afterwards. Any advice gratefully received! Stewart
stewart
A100man
PostPosted: 15:19 - 16 Mar 2015    Post subject: Reply with quote
Various options depending on how bad it is..
Not much rust generally clean tank: - shake about with a few handfuls of washed gravel, rinse then use an in-line filter
Far bit of rust but no pin holes:-
Chemicals - Citric acid (mild) as used in domestic descaler - wilko sell it, Hydrochloric acid (sronger) as used in brick cleaners
Electrolysis - lots of articles online works ok but takes time.
Lots of rust & leaking - clean-up as best you can using above method dry thoroughly and line with POR-15 or whatever is latest flavour of the month, or solder or send of rewelding..
J
rednog
PostPosted: 15:49 - 16 Mar 2015    Post subject: Reply with quote
Thanks for this, J. Doesn't look like I need to use sealer/liner then. I tried that on a ZX400 tank with pinholes once, and it didn't work anyway!
stewart
A100man
PostPosted: 15:58 - 16 Mar 2015    Post subject: Reply with quote
I remember seeing another article where a guy managed to get his tank inside a tumble dryer packed with cushions - he had previously added gravel (acquaruium pebbles ?) and taped up the holes - he then ran it on the cold setting Shocked ..
rednog
PostPosted: 16:12 - 16 Mar 2015    Post subject: Reply with quote
That'll go down well!
stewart
Taught2BCauti...
PostPosted: 22:34 - 16 Mar 2015    Post subject: Reply with quote
A length of chain dropped into the tank also works well, and easy to fish out afterwards with a wire coathanger.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
rednog
PostPosted: 23:40 - 16 Mar 2015    Post subject: Reply with quote
Worth a go.....thanks
stewart
Moo.
PostPosted: 09:38 - 17 Mar 2015    Post subject: Reply with quote
Could look at Deox-C which is a rust killer.
Make up a solution inside the tank and leave it a while to kill all the rust. Or if the outside is rust too, just drop the whole tank in the stuff.
Bottle makes 20 litres of solution that can be re-used until its turned black.
https://www.opieoils.co.uk/p-73829-bilt-hamber-deox-c-concentrated-rust-remover.aspx
Use google for reviews Wink
A2 Passed 18/6/10
rednog
PostPosted: 10:06 - 17 Mar 2015    Post subject: Reply with quote
Hadn't heard of that one, so thanks.........
stewart
mudcow007
PostPosted: 10:30 - 17 Mar 2015    Post subject: Reply with quote
me personally would be looking at getting a replacement tank - if possible.
i had my tank soldered then sealed using petseal, which melted - causing even more issues
The last post was made 11 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 61.21 Kb
