Can anyone identify this problem?
Craigwheeler
PostPosted: 17:54 - 16 Mar 2015    Post subject: Can anyone identify this problem? Reply with quote
The clutch cable won't spring back, it feels stiff (see pic) of I move it manually it will engage but I don't know why it's so stiff. Any help would be much appreciated as I don't want to let a garage rip me off. Cheers
Highside
PostPosted: 18:01 - 16 Mar 2015    Post subject: Reply with quote
Hmmm ,Maybe take the clutch cable out and lube it with some wd-40 ?
Or check your major adjustment ?
What bike is it ?
Craigwheeler
PostPosted: 18:05 - 16 Mar 2015    Post subject: Reply with quote
It's a honda cg 125, I tried lube but it's seriously stiff.
The bike was running fine then all of a sudden it wouldn't allow me to change gear. I fitted a new clutch cable prior to this thinking that was the problem then upon fitting it stumbled across this issue.
Paddy Blake
PostPosted: 19:20 - 16 Mar 2015    Post subject: Reply with quote
Check that the cable is the same length as the old one and
not shorter.
Craigwheeler
PostPosted: 19:24 - 16 Mar 2015    Post subject: Reply with quote
not shorter.
The cable is slack, but that's because it's not springing back and pulling it 50mm or so to tighten it. It's stuck at 12 o clock when it should be 10 o'clock
NJD
PostPosted: 19:27 - 16 Mar 2015    Post subject: Reply with quote
Take the engine casing off and visually inspect inside, it could be that road salt (or something else) has worked its way inside and corroded the parts.
I rode my bike all through winter without any issues, then one day I engaged into 1st gear and the clutch wouldn't disengage, long story short the arm was getting stuck (in the same position as yours) due to road salt having worked its way inside where the arm goes into the engine casing and corroding the insides.
Get er off is the only way to check.
Craigwheeler
PostPosted: 19:30 - 16 Mar 2015    Post subject: Reply with quote
Yep that's what im gonna do, I jut wanted to make sure before I take off all the casing and potentially tinker with something that doesn't need it. Was it relatively simple to fix?
NJD
PostPosted: 19:36 - 16 Mar 2015    Post subject: Reply with quote
Mine was under warranty so cannot help sadly, as far as I'm aware they just cleaned the insides out.. and advised to spray WD40 in that very small gap between the arm and the engine case to avoid it in the future.
Although upon visiting today (for a different reason) the mechanic said once it's solved that should be it, so can probably lay of the WD40 now that the weathers improved and road salt isn't being used.
I'd say get it off, inspect inside.. if required post pictures, might be that some parts needs replacing.. hard to say without inspecting.
misscrabstick
PostPosted: 19:37 - 16 Mar 2015    Post subject: Reply with quote
There is a shaft underneath that lever that goes down into the casing, I wonder if Mr winter salty has done a number on the shaft and corroded it up so it's binding in the casing, your next move is logical, casing off and have a look see.
Craigwheeler
PostPosted: 19:40 - 16 Mar 2015    Post subject: Reply with quote
Cheers for the advice. I'll get it off Tomo and see what's what.
cresad
PostPosted: 23:19 - 16 Mar 2015    Post subject: Reply with quote
We had a similar problem with my son's bike , a chinese version of the same engine. It turned out that the shaft that runs down inside the casing that's attached to the lever had corroded in the runners. Don't forget you'll need a gasket for the case and oil.
Adam
The last post was made 11 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 68.65 Kb
