Modem can't handle power flickers - UPS time?
metalangel
PostPosted: 20:36 - 17 Mar 2015    Post subject: Modem can't handle power flickers - UPS time? Reply with quote
Power flickers in my neighbourhood are proving very annoying – especially because the first thing to go off is my cable modem. Everything else: router, TV, lights… it all stays on just fine, but BOOM there goes my internet connection.
Is it worth buying a cheap UPS to keep my internet connection going? I’m pretty sick of being booted out of games by something that isn’t even a legit power failure. Do I have any other options?
dydey90
PostPosted: 21:09 - 17 Mar 2015    Post subject: Reply with quote
Buy a battery pack for £10-£20 that's meant for phones? I have one that outputs 2.1A over usb so it should manage it.
bamt
PostPosted: 21:38 - 17 Mar 2015    Post subject: Reply with quote
That's fine if the battery pack can be trickle-charged whilst delivering power to the modem (not all can), and the modem is 5V.
I'd go for the UPS. In fact, I did Very Happy I used to live somewhere that the power dropped very regularly, a big UPS to power my router (which back then was a PC connecting my ISDN modem to the Ethernet in the house), and a smaller one to keep the DECT phone and PVRs alive.
It's quite nice still having full net access when the rest of the street is in darkness. A small UPS will power a router for ages.
metalangel
PostPosted: 21:57 - 17 Mar 2015    Post subject: Reply with quote
It's a Thomson DCM476, 12v 1A.
Thinking of this one, it would keep the router and modem going - laptop can take care of itself.
https://www.thesource.ca/estore/product.aspx?language=en-CA&catalog=Online&category=UPS&product=6114019
UrbanRacer
PostPosted: 11:08 - 18 Mar 2015    Post subject: Reply with quote
You can get a decent APC UPS for about £50-60. at full load it'll give you about 5mins of uptime.
https://www.comms-express.com/products/apc-be400-uk-back-ups-400va
wots
PostPosted: 11:13 - 18 Mar 2015    Post subject: Reply with quote
I bought a pair of these for my HP Microservers, they were less than this at the time. Software is crap (but that isn't an issue for you), otherwise they are quite good. I got half hour runtime for one server. A modem should easily last an hour.
https://www.ebuyer.com/196277-liebert-psp-500mt-500va-300w-230v-usb-ups-psp500mt3-230u
prawny1
PostPosted: 14:52 - 18 Mar 2015    Post subject: Reply with quote
can you not wire a voltage smoothing capacitor in parallel after the power jack/ power supply? to deal with any small voltage drop
If your power dips are small enough to not effect the rest of your equipment then I can't see you needing a ups for it just some reserve on the power feed.
You won't need a diode or anything fancy unless you want to eliminate pulsing/ripple, just a capacitor of the correct voltage and adequate capacity wired inside the modem (assuming you have space available).
hellkat wrote:
metalangel
PostPosted: 03:22 - 19 Mar 2015    Post subject: Reply with quote
prawny1 wrote:
can you not wire a voltage smoothing capacitor in after the power jack/ power supply? to deal with any small voltage drop
You won't need a diode or anything fancy unless you want to eliminate pulsing/ripple, just a capacitor of the correct voltage and adequate capacity wired inside the modem (using you have space available).
Interesting but I don't have the tools and the last time I did any electronics tinkering was in high school.
Charlie
PostPosted: 22:13 - 19 Mar 2015    Post subject: Reply with quote
Try another 12v 1A converted first? Hopefully a standard barrel connector.
The last post was made 11 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 63.1 Kb
