Where can I get one of these?
Iain.
PostPosted: 14:14 - 18 Mar 2015    Post subject: Where can I get one of these? Reply with quote
Bellmouths, Velocity Stacks, Trumpets, Ram Horns whatever you want to call them...these thingys;
https://www.motorcycle-exhausts.co.uk/admin/images/CR%20Alloy%20Stacks.jpg
Sits on the carb like this;
https://www.ooracing.com/store/images/source/Carbs/FCR-28.jpg
Needs to be of clamp on/bolt on fitment and have an ID of 55mm.
I can't seem to find anything suitable - any suggestions? Confused
sickpup
Old Timer
PostPosted: 14:22 - 18 Mar 2015    Post subject: Reply with quote
Be easier if you said what bike and what length?
Iain.
PostPosted: 14:40 - 18 Mar 2015    Post subject: Reply with quote
Baotian BT49QT-20C.
However, the only standard bits of the motor are the crankcases - the carb is a Stage 6 version of a 30mm Keihin PWK flatslide.
Would ideally like it to be around 50-70mm long. Not going for a performance gain, I simply plan to run no filter & this moves the air intake out of the path of all the crap getting flung off the back wheel. Also makes the carb throat easily chokeable by hand as the carb has a non cable operated choke that isn't very easily acessable.
sidewinder
PostPosted: 16:44 - 18 Mar 2015    Post subject: Reply with quote
Demon tweets most likely do Thumbs Up
https://www.demon-tweeks.co.uk/motorsport/carburettors-accessories/itg-flanged-full-radius-bolt-on-ram-pipe
https://www.demon-tweeks.co.uk/motorsport/carburettors-accessories/pipercross-full-radius-ram-pipes
wr6133
PostPosted: 17:02 - 18 Mar 2015    Post subject: Reply with quote
On my shite-ped I just used part of the tube from the old airbox - carb to do this, cut it down a fair bit, attached to carb and angled upward away from back wheel. If your old tube is too narrow for the new carb you could get similar results with any old bit of plastic tube the right diameter.
Iain.
PostPosted: 18:46 - 18 Mar 2015    Post subject: Reply with quote
Unfourtunately the ones linked are suitable for the two bolt Dellorto/Weber style carbs rather than the grub screw bolt on style I'd need - My carb doesn't have the two mounting points.
https://www.feked.com/images/detailed/0/fkbell422-1-600.jpg
OOracing seem to go up to 50mm, but I cant seem to find anyone making anything that'll fit the monster carb Laughing
PostPosted: 19:14 - 18 Mar 2015    Post subject: Reply with quote
Some plastic drain and a jubilee clip?
Matt B
PostPosted: 20:00 - 18 Mar 2015    Post subject: Reply with quote
55mm is an odd size compared to what is available. Bodge it with a bit of silicone hose and a cable tie Thumbs Up
Nemo
PostPosted: 22:31 - 18 Mar 2015    Post subject: Reply with quote
Get the 50mm, take it to a machinist and get them to turn another 5mm out?
Fussy git.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Major Doss
PostPosted: 10:49 - 19 Mar 2015    Post subject: Reply with quote
Or 2.5 mm Wink ^
PostPosted: 11:08 - 19 Mar 2015    Post subject: Reply with quote
Iain. wrote:
Baotian BT49QT-20C.
Might be good for a blast but running open bellmouths on the road is likely to make the engine eat itself. Still, I guess if they are cheap there's no harm.
Quite likely I would be able to modify the mount of one if you brought it up to me.
The last post was made 11 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 70.63 Kb
