gg or hh pads?
andyscooter
PostPosted: 18:34 - 18 Mar 2015    Post subject: gg or hh pads? Reply with quote
For normal road riding use what dou you use and why?
GaryJM
PostPosted: 18:43 - 18 Mar 2015    Post subject: Reply with quote
I use sintered more bite to them, can't say that I have particularly notice excessive disc wear on any bike I've owned ,but they do allegedly increase wear on the discs.
mentalboy
PostPosted: 18:45 - 18 Mar 2015    Post subject: Reply with quote
gg's are horses, innit? Laughing
HH sintered's for me. Tried the organics once and they wore through in no time at all, whereas I've never suffered the catastrophic effects of disc wear that HH haters will harp on about.
Make mine a Corona.
PostPosted: 18:50 - 18 Mar 2015    Post subject: Reply with quote
HH for the front either for the rear.
I got 70,000 miles out of a set of discs using HH pads the whole time. I really wouldn't worry about wear.
SandTiger
PostPosted: 18:51 - 18 Mar 2015    Post subject: Reply with quote
Current on the mt is sintered at the front, organic on the rear.
2015 Kawasaki Z800e "Zee"
2006 Yamaha MT-03 "Mary Jane"
2011 Yamaha YBR125 "Ally"
chickenstrip
PostPosted: 20:35 - 18 Mar 2015    Post subject: Reply with quote
Sintered on the front, standard on the back is my preference. Although the last pads that got replaced gave more feel than the current EBC fit, and just seemed to last forever. I rather suspect they were genuine Yam, and I will go back to that at some point, see what I reckon then.
barrkel
PostPosted: 22:15 - 18 Mar 2015    Post subject: Reply with quote
Honda OEM pads, which are generally sintered, at least on the bikes I ride.
Nemo
PostPosted: 22:28 - 18 Mar 2015    Post subject: Reply with quote
I usually go OEM, mostly because you get twice the amount of material than other makes, and only a tenner more in some cases.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
HughiusMaximu...
PostPosted: 22:45 - 18 Mar 2015    Post subject: Reply with quote
Im glad to see the consensus is for hh cause I just ordered some for my cbr600f.
To be honest I hac to order twice cause I didnt know there were only two pads per pack....
Rookie move.... Embarassed
DJP
PostPosted: 10:13 - 19 Mar 2015    Post subject: Reply with quote
GG for me.
HH are alright but they need some heat in them to work properly.
Fine when you're cracking on in summer, but a bit wooden when you're commuting in winter.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
Dave70
PostPosted: 11:54 - 19 Mar 2015    Post subject: Reply with quote
Sintered on the front because 1) it gets a lot more use/wear and 2) because I generally want more/better grip there.
Normal on the rear as 1) it usually hardly gets used and 2) I really don't want too much grip on the back wheel as bad things can happen.
Old Git Racing
PostPosted: 11:57 - 19 Mar 2015    Post subject: Reply with quote
SBS HH in the front, never use the back so it probably still has the original Brembo pads in from 2005.
OGR
mentalboy
PostPosted: 12:19 - 19 Mar 2015    Post subject: Reply with quote
Which was my thinking with using HH's on the front and trying GG's on the rear. I do actually use my rear brake a fair bit - try overcooking bends and using your fronts!!! The GG's lasted less than a year and I thought the odd noises from the rear must have been issues with the anti-squeal stuff as the pads were all but new.
No, the pads wore out and trashed the disc too - only time I've ever had to replace a disc.
Whilst the HH's may have a better bite, which most people don't want on the rear, the Zed has a single pot on the rear and with it's 250KG weight, when I use the rear it still doesn't feel overly positive. Grab the fronts and they will lock up every time!
Make mine a Corona.
chickenstrip
PostPosted: 12:22 - 19 Mar 2015    Post subject: Reply with quote
Try not to Wink
I'm a fine one to talk Laughing
mentalboy
PostPosted: 12:29 - 19 Mar 2015    Post subject: Reply with quote
chickenstrip wrote:
Try not to Wink
What? Overcook or use fronts? Wink
Make mine a Corona.
chickenstrip
PostPosted: 12:40 - 19 Mar 2015    Post subject: Reply with quote
I was under the impression that you meant the two together. But yer pays yer money... Smile
UrbanRacer
PostPosted: 12:58 - 19 Mar 2015    Post subject: Reply with quote
I recommend you avoid buying Carbone Lorraine HH pads, they don't last long and the brake dust they generate is ridiculous.
Dcwhite1984
PostPosted: 13:09 - 19 Mar 2015    Post subject: Reply with quote
DJP wrote:
GG for me.
The HH shouldn't need too much heat in them, the letters are a reference to the braking friction created, H being the highest. If you just had a H rated pad that would mean that they work when hot (normally racing pads i believe), the rating HH means they work when hot or cold, obviously they will be better when hot though Thumbs Up
The trick to life is to not get too attached to it.........
DJP
PostPosted: 09:26 - 22 Mar 2015    Post subject: Reply with quote
It's just been my experience of HH vs GG.
Maybe I just prefer the feel of the latter.
Suzuki Bandit 1250
The last post was made 11 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 105.99 Kb
