Front end click?!
joezxr
PostPosted: 09:10 - 19 Mar 2015    Post subject: Front end click?! Reply with quote
I have a Kawasaki 636 2003 B1H and whenever I slam the brakes on there is a really loud click noise!
Iv changed the wheel bearings, the headstock bearings and just serviced the calipers and forks and basically stripped the whole front end down and build it back up but it STILL does it!! Neutral
I'm actually getting worried now has anyone else had this before or have any idea what it could be?
Matt B
PostPosted: 09:27 - 19 Mar 2015    Post subject: Reply with quote
Pads moving inside the caliper maybe? Have you got all the shims/anti rattle bits in and the right way round?
carlosvalderr...
PostPosted: 10:46 - 19 Mar 2015    Post subject: Reply with quote
I've seen something like this on bikes when the fit between the top yoke and stem has opened out.
The stem is usually a snug fit in to the yoke, but if there's too much clearance, or the clamp load from the top nut isn't enough, you can get a knocking type noise. I've not seen it on a sportsbike though, so far only on long travel forks, such as adventure and offroaders.
You can eliminate it as a cause by improving the tightness of the joint, in the past I've used shim, or gauge steel. It's very thin accurate sheet steel, and something like a 0.1mm ring of it can be slid inside the yoke to create a tighter fit.
Otherwise, just wrapping some sellotape round the stem, or knocking a bit of matchstick between the stem and yoke will be enough to allow you to hear a difference and know if it's an issue.
At your own risk, you could also just bollock the top nut up massively to increase the clamp load on the yoke. Thread stripping or damage is possible though...
Snorty
PostPosted: 11:19 - 19 Mar 2015    Post subject: Reply with quote
Sounds like the pads moving in the calipers when they touch the disc.
That, or also as mentioned, loose disc bobbins. Does the noise happen if you squeeze the front brake and rock the bike back and forth?
FlightRisk
PostPosted: 12:13 - 19 Mar 2015    Post subject: Reply with quote
Headstock bearing could be ok but need adjustment.
Get the front wheel in the air, crouch in front of the bike, grab the forks down near the axle and push-pull in the front to back of the bike direction. If you feel a click and a little movement your headstock bearing is loose.
Honda CB500S
CaNsA
PostPosted: 12:17 - 19 Mar 2015    Post subject: Reply with quote
Have the bushes in the forks been replaced?
joezxr
PostPosted: 15:56 - 22 Mar 2015    Post subject: Reply with quote
Thanks for the replies
Iv had a feel of the disc and they do not move with the force of my arms so I don't think its them!
Iv also played around with tightness of the headstock and its still always there >Sad
It seems to happen most when say I push the bike up a curb when parking its like a big click from the right hand side I'd say!
The shims in the fork have not been replaced as the mechanic said the forks internals were in good condition!
As said it could be the pads rattling around but they do have retaining pins hmmm, Im gonna get it on a headstock paddock and give things a pull see what I can find!
Matt B
PostPosted: 11:44 - 23 Mar 2015    Post subject: Reply with quote
I had the same sort of thing on the Pan, it would click going over a speed bump and also braking at low speeds.
I stripped the front brakes and although the plates were all in there the pads had been put in dry - no copper grease. I cleaned the calipers up and refitted the pads with copper grease in all the right places. Click stopped, sorted.
joezxr
PostPosted: 21:08 - 23 Mar 2015    Post subject: Reply with quote
I'm gonna get some copper grease on the backs of the pads and see if thats helps in that case matt!
As for the noise snorty it only occurs when I take a sudden hit like a speed bump or a pothole or mounting a curb!
carlosvalderr...
PostPosted: 07:26 - 24 Mar 2015    Post subject: Reply with quote
It's unlikely to be brake related if it's not occurring as the brakes are applied.
The occurence during high speed suspension compressions is exactly the symptom of the loose yoke fit.
TBF, I think I'm right when I assume the ZX has a conventional yoke, and not a Ducati type with a pinch bolt on the stem?
Commuter_Tim
PostPosted: 19:22 - 24 Mar 2015    Post subject: Reply with quote
To re-enforce what Cansa has said, my CB500 clicked like that until recently, the oil seals were blown, and bushes were completely shagged.
The bushes weren't clicking for me unless the forks were considerably compressed.
I ride a Bandit 600... badly.
Matt B
PostPosted: 19:29 - 24 Mar 2015    Post subject: Reply with quote
OP did say:
Cyclingbiker
PostPosted: 20:46 - 24 Mar 2015    Post subject: Reply with quote
I too am suffering from this annoying problem on my CB500 and I suspect the fork bushes, I replaced both oil seals 18 months ago and didn't note anything untoward at the time. The head stock bearings were replaced last year as they were very notchy and though they are are greased up and adjusted just so the noise still remains. Mainly it is when going over a sharp speed bump or through a pothole at low speed.
Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12
PostPosted: 11:00 - 25 Mar 2015    Post subject: Reply with quote
OP did say:
OP also said
It's the forks. I'm with Cansa. Thumbs Up
CaNsA
PostPosted: 12:26 - 25 Mar 2015    Post subject: Reply with quote
I was wondering who's hand was gently stroking the back of my neck..
joezxr
PostPosted: 17:41 - 25 Mar 2015    Post subject: Reply with quote
The triple tree has double pinch bolts on the lower yoke, and singles on the top that are all torqued up and Then the big old locking but in the middle of the top yoke! No movement to be found
CaNsA
PostPosted: 17:44 - 25 Mar 2015    Post subject: Reply with quote
Sounds like someone just cant be arsed splitting the forks again Very Happy
carlosvalderr...
PostPosted: 07:48 - 26 Mar 2015    Post subject: Reply with quote
It's the joint beneath the big nut in the middle which I've found issue with, however, never with a sportsbike so far.
The fit between the yoke and stem is a clearance fit, and the stem is only stopped from being slid back and forth in the yoke by the friction of the surface interaction between the nut and yoke. Contamination, wear and under tightening can all allow this joint to slip.
However, the only bikes I've seen this on have been a TDM850, a Yamaha Tenere 660, and a DRz400. All have long-ish forks, and hence a long lever arm to generate the moment to make the joint slip. The symptoms of when it happened are identical to yours though.
All showed signs of the yoke being 'polished' by the motion. My assumption of the cause was a combination of wear, under-tightening, and unfortunate tolerance stacks in the bike from new. On a sportsbike, I guess an under tightened nut and a load of wheelies...
It's not too hard to check if you have feeler gauges. Pop just the yoke nut off, and see if a thin feeler will go between the stem and yoke bore at the front of the stem, probably opposite the ignition barrel. If you've no feeler gauges, try a fag paper folded over a few times, kitchen foil or something similarly thin.
If you can't check it, just clean up the threads and mating face on the nut and yoke, apply copperslip to the threads ONLY, not the contact face, then tighten it down to factory spec +20%. This may not fix it if it even is the issue, but it might be worth a 5 minute job.
It may be a very small gap, but closing it off or stopping the movement fixed all three of the bikes. However, it's pretty rare as an issue, so I imagine a problem with the fork slider bushes is more likely. Could be worth a quick check though to eliminate it.
Good luck.
joezxr
PostPosted: 10:43 - 26 Mar 2015    Post subject: Reply with quote
Good luck.
Hmmm I see where your coming from but wouldn't the tapered bearings sat in their braces being torqued in by the pressure of the top nut stop this problem happening?
Either way I'll check it out when I get a minute!
P.
PostPosted: 10:54 - 26 Mar 2015    Post subject: Reply with quote
So...
Are you going to do that first and resolve the issue?
joezxr
PostPosted: 12:11 - 26 Mar 2015    Post subject: Reply with quote
Just an update iv noticed slamming the brakes on it makes the click noise every now and again!
As for the bushes the mechanic that serviced the forks said they do not need replacing when I had my mot the other day!
carlosvalderr...
PostPosted: 12:43 - 26 Mar 2015    Post subject: Reply with quote
The top nut, in theory, has no effect on the bearings.
The bearings will have an adjuster nut, to set the bearing preload, which is typically set at a low value, say 5-15Nm on a SAC ball bearing, a little less on a taper roller. Then a locking nut, with or without a washer in between to 'lock' the adjustment and prevent it slackening off. This will be much tighter, probably 40Nm or so, and the bottom nut may have to be held still while the locking nut is tightened.
The yoke fits on top of these, and the top nut simply clamps the yoke to the locknut, and is whacked up to anything from 60-110Nm depenfding on the bike.
Theoretically, the locknut isolates the adjuster nut from being affected by the big topnut clamp load, however, the tension that's put into the stem stretches it slightly taking pressure off the drive flank of the adjuster thread profile, and so will actually take a bit of clamp load off the bearings.
You're right in that there is a clearance gap between the inner upper bearing race and the stem, but it's far smaller than between the stem and yoke, and as such is far less likely to be having any effect.
If you're anywhere near leicester, I'll offer a hand. Thumbs Up
P.
PostPosted: 17:54 - 26 Mar 2015    Post subject: Reply with quote
Assume he stripped them down and looked... because you'll either not have a noise or they'll be fine. Currently you have the noise.
SQL
PostPosted: 18:00 - 26 Mar 2015    Post subject: Reply with quote
**Wild Card**
I had a clicking noise on the bandit under heavy braking and steering, it was the mudguard cracked clicking when the speedo cable pushed against it
The last post was made 10 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 135.05 Kb
