Honda cbr Indicator is not working
rockerpapaz
PostPosted: 19:23 - 19 Mar 2015    Post subject: Honda cbr Indicator is not working Reply with quote
Hi I have Honda Cbr 125 2013...I'm experiencing an issue of one Indicator is not working (which is front one) but the same side of back one is working but it remains constant ( it doesn't flashes or turns on and of).... any help full suggestions for me???
Jim Mc
PostPosted: 19:28 - 19 Mar 2015    Post subject: Reply with quote
Have you considered replacing the bulb?
rockerpapaz
PostPosted: 20:05 - 19 Mar 2015    Post subject: Reply with quote
Cheers for quick reply....i will do and see what happens
Dave70
PostPosted: 20:07 - 19 Mar 2015    Post subject: Reply with quote
Shocked Laughing
andyscooter
PostPosted: 20:46 - 19 Mar 2015    Post subject: Reply with quote
Ffs
Shocked really
notbike
PostPosted: 20:47 - 19 Mar 2015    Post subject: Reply with quote
replace bulb
if not that
check connections
if not that
replace relay
if not that
aliens
Accuhaler
PostPosted: 22:10 - 19 Mar 2015    Post subject: Reply with quote
Right, who's trying to troll the forums?
monkeybiker
PostPosted: 00:36 - 20 Mar 2015    Post subject: Reply with quote
I'm a bit confused as to why one indicator is on constant. He hasn't said but I assume the other side indicators are working correctly.
Does it have two indicator relays or just the one?
notbike
PostPosted: 01:35 - 20 Mar 2015    Post subject: Reply with quote
When a bulb went kaput on my ninja the other side's indicator was solid until the dodgy bulb was replaced.
I don't know exactly how it works or if it's designed as a troubleshooting mechanism to let you know there's an interruption in the circuit, but yeah the other indicator being constant is a result of that one being popped or dodgy, not as a result of the whole indicator circuit being rekt.
monkeybiker
PostPosted: 04:43 - 20 Mar 2015    Post subject: Reply with quote
When I have had indicator bulbs go the one working would flash faster than normal.
PostPosted: 09:56 - 20 Mar 2015    Post subject: Reply with quote
It's just the relay not getting sufficient draw to electrocute the magic imp that lives inside it enough to get him to flip the switch.
More modern relays use invisible pixies instead with a better work ethic that flash at a constant rate regardless of the draw, whether that's with incandescent or LED bulbs.
The last post was made 11 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 71.75 Kb
