Decent Tyre Pump for Varadero
turningCircle
PostPosted: 15:38 - 22 Mar 2015    Post subject: Decent Tyre Pump for Varadero Reply with quote
Hi All,
Looking for any recommendations on decent 12V tyre inflators which can be powered from the bike battery. (I don't have a car). Have been looking at this:
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/17728
(bit pricey but looks decent). It mentions that it only supports Schrader valves and I don't have an effing clue what valves my Varadero has! I presume it's a pretty standard type of valve on most tyres?
Happy riding Cool
CaNsA
PostPosted: 15:40 - 22 Mar 2015    Post subject: Reply with quote
Google is your friend.
https://www.google.com/search?q=Schrader+valves
sidewinder
PostPosted: 16:26 - 22 Mar 2015    Post subject: Reply with quote
A schrader is fitted to all cars bikes etc.. Presta is the skinny type you find on push bikes Thumbs Up
andyscooter
PostPosted: 19:53 - 22 Mar 2015    Post subject: Reply with quote
I have a ring one
It has clips that connect to the battery
And a screw on valve
drbaig
PostPosted: 19:58 - 22 Mar 2015    Post subject: Reply with quote
Just get a bicycle pump or a foot pump.
I use my bicycle track pump for the bike.
yzf 600r Very Happy
Peirre oBollox
PostPosted: 20:22 - 22 Mar 2015    Post subject: Reply with quote
andyscooter wrote:
I have a ring one
Wilkinson's sell them for around £10-£15, they're strong and reliable
Taught2BCauti...
PostPosted: 22:37 - 22 Mar 2015    Post subject: Reply with quote
Run the engine whilst using it - it would be quite ironic if you flattened the battery whilst pumping-up a tyre - and if you have the PGM-Fi version, you can't bump-start it on a flat battery!
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Carvel
PostPosted: 22:49 - 22 Mar 2015    Post subject: Reply with quote
Why?
Northern Monkey
PostPosted: 22:56 - 22 Mar 2015    Post subject: Reply with quote
Why?
My MSX uses Honda's PGM-Fi. I can bump start that with a completely flat battery
Taught2BCauti...
PostPosted: 23:05 - 22 Mar 2015    Post subject: Reply with quote
You might just get away with it if you pull the headlamp fuse - but if the battery voltage drops below 12v, there's not enough juice to run the lights, the ECU, the heaters in the O2 sensors, the fuel pump and the injectors.
This doesn't happen on the carb version, and as far as I know, only affects the Varadero PGM-Fi.
Northern Monkey
PostPosted: 23:18 - 22 Mar 2015    Post subject: Reply with quote
It was sufficiently flat that the instrument panel didn't switch on, and there was no noise from the fuel pump.
Got it to about 5mph in 2nd, jumped on, dropped the clutch, and away it went
Baffler186
PostPosted: 17:16 - 23 Mar 2015    Post subject: Reply with quote
Look on wiggle, Amazon or EBay for a track pump. They are designed for push bikes, and can easily inflate a skinny road tyre to 120psi. I paid about £17 new for mine. It has both presta and shrader ends on it. Save farting about with a 12v compressor, a few pumps and you're done
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
Wonko The Sane
PostPosted: 22:17 - 23 Mar 2015    Post subject: Reply with quote
Vincent wrote:
Just bought one from Maplins and did a post......can't seem to find it now Confused
Some of the manual ones like stirrup pumps are pretty good and BMW do one for their older bikes that's small but works well.
Stirrup pump is a 'track pump' in cycling speak.
I've got a halfords own double barrel foot pump, does the job of topping up my ZZR's tyres, hardest part is accessing the front valve as it's tucked between the two front brake disks.
The last post was made 11 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 87.27 Kb
