| andym |
 andym World Chat Champion
| RhynoCZ |
 RhynoCZ Super Spammer
| andym |
| temeluchus |
| mysterious_rider |
 mysterious_rider World Chat Champion
| RhynoCZ |
| andym |
| MarJay |
 MarJay But it's British!
| WD Forte |
 WD Forte World Chat Champion
| weasley |
 weasley World Chat Champion
| Robby |
 Robby Dirty Old Man
| RhynoCZ |
 Posted: 18:32 - 25 Mar 2015 Post subject: |
| andym wrote: | Lets see:
Vacuum fed, so no fuel pump. |
https://www.cmsnl.com/cbr600f-1997-france_model2347/fuel-pump-assy_16710mal601/#.VRLwhfmG_VQ
Maybe the previous owner took the pump off and now the carbs are starving, when you run it at constant high speed. Then, when you slow down, the carbs don't need that much of fuel, so there's enough time for the fuel to fill up the bowls. These kind of pumps only help, when you ride it at constant high speed, they do not do much when going slow.
Telling us, you took the carbs out three times and you didn't notice there was a fuel pump, seems suspicious.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| andym |
 Posted: 19:42 - 25 Mar 2015 Post subject: |
| RhynoCZ wrote: | https://www.cmsnl.com/cbr600f-1997-france_model2347/fuel-pump-assy_16710mal601/#.VRLwhfmG_VQ
Telling us, you took the carbs out three times and you didn't notice there was a fuel pump seems suspicious.  |
OK I'll take being called a complete idiot over this one, but where should the fuel pump be fitted on a '92 CBR600f2 (or fp)? This bike hasn't been subjected to my normal meddling, so I've only had the fairing, seat, tank, air box, carbs, coils, radiator and lights off.... and with the exception of the alarm that someone had disconnected at some point..... there are no loose wires, unused plugs, holes in the frame or elsewhere that looks like a pump should have been fitted, missing fuses or relays. OK as mentioned in a previous post, it did have a new tap fitted last year which does have the vacuum pipe attachment, so whether it has been converted over I don't know, but surely there would have been some telltale sign of a pump having been fitted in the past? I'm not saying it never had one as looking on ebay there is pumps for sale for all of the CBR's, so I'm much confused.
| Robby wrote: | You say you've cleaned the carbs 3 times while you've owned the bike. This rings alarm bells for me, carbs should only need cleaning if the bike has been standing for so long that the fuel has turned to varnish - in which case they need to be cleaned once, and really well.
Common problems on bike that have had the carbs cleaned:
1. Knackered throttle shaft seals. Would have been ok, but if the carbs were separate off the rail then these seals get disturbed and often need replacing. Often shows up as a weak idle and weak low speed running, getting worse as the engine warms up.
2. Split/torn/folded/poorly fitting carb rubbers, often caused by cack-handedness. More common on straight-4s because the carbs can be such a swine to refit.
3. Float heights all wrong. I recommend measuring the fuel level by using a bit of clear tube attached to the carb drain rather than by setting float heights, it's more accurate and easier to check. Still just as hard to adjust.
4. Clogged mixture circuits - because people decide to clean their carbs by cleaning the big holes that always have solvent running through them, not the small holes that like to clog.
5. Air leaks from the vacuum balancing ports - because they were only covered by a rubber cover that has hardened with age and didn't like being moved, or because they lost the tiny copper washer that sits under the plug for screw-blanked ports.
Of course, it's a CBR600 so it could just be your reg/rec shitting itself. |
First time I done the carbs it was while I was at college and I had 2 1/2 hours to strip the bike, clean them and rebuild everything. I found that the idle jets were blocked. They were cleared and I had pretty much run out of time and had to rebuild the bike again.
Second time, I was working in my lock-up and I got the carbs off, check the diaphragms etc then the weather got the better of me.
Third time, I decided to get another can of carb cleaner, got the carbs off and at the risk of getting in to trouble from the concierge, brought them up to the flat.
They were stripped to this point:
https://img.photobucket.com/albums/v320/andy36586/DSC_0391_zpsazjkvblq.jpg
A full can of carb cleaner was used and this time I made sure I sprayed all the holes, gaps, nooks and crannies.... unfortunately I didn't have any compressed air to blow through everything to check it was all clear.
Also
1. The carbs weren't separated, as I've only done it once and even then it wasn't necessary... idle is fine, low speed is fine, runs exactly the same cold or warm.
2. I've had the carbs out of: 50cc scooter (I know it's only a silly little 1), 125 intruder (same again), GPz 750 (2 days to refit them, and even then it was brute force and ignorance that was used, and the bike ran fine afterwards), zxr 750 h1 (which the carbs had been stripped down and rebuilt several times, and I will admit that because they had been rebuilt from 2 sets the bike never played fair), and the CBR.
3. This one I will check tomorrow.... but again wouldn't this affect the engine at high revs rather than affect speed?
4. See above
5. The bike had this problem since I bought it, last week I got the extensions and rubber pipes to make extensions to make balancing easier. OK it was only screws and washers that were in there previously, the new fittings had rubber O-rings and were thread-locked in to place..... maybe it was the balancing the carbs (finally), but now the bike is easier to start, will quickly get to 3k rpm with the choke in the morning, responds instantly to twisting the throttle on the motorway, slightly more power etc
OK I know I'm sounding ungrateful here, I'm not, thank you all for the replies |
| temeluchus |
| andym |
 Posted: 21:49 - 25 Mar 2015 Post subject: |
Up yours
OK I can't work out what is going on with this bike..... while looking for some pictures of my set up I keep coming across things like this:
https://i253.photobucket.com/albums/hh50/julietjameson/f3carbremoval/Dsc03082a.jpg
But at the same time when I search for fuel taps they've all had the vacuum port on them.... why would it need that plus a fuel pump?
I'll get a photo of the setup tomorrow. |
| Snod Blatter |
 Snod Blatter Crazy Courier
| davebike |
 davebike World Chat Champion
 Posted: 08:41 - 26 Mar 2015 Post subject: |
Sounds to me like the missing fuel pump is the problem exactly the symptoms of a poorly pump
Pump is held to the frame below and slightly to the rear of the back of the tank by a large rummer fitting
Fuel line from tank though in line filter to pump them to carb ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| Copycat73 |
 Copycat73 World Chat Champion
| RhynoCZ |
 Posted: 12:51 - 26 Mar 2015 Post subject: |
Rhyno 1:0 BCF  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Suntan Sid |
 Posted: 13:10 - 26 Mar 2015 Post subject: |
Probably no help but, I had a 1992 CBR600F, in Cyprus, it had normal carbs, not flat slides and there was no fuel pump.
What it did have was restrictors in the inlet rubbers, before I removed them! ____________________ "Everybody needs money, that's why they call it money!"  |
| andym |
 Posted: 16:01 - 26 Mar 2015 Post subject: |
Not sure it makes a difference... but mine is an fp |
| weasley |
| andym |
 Posted: 16:50 - 26 Mar 2015 Post subject: |
OK this is bugging me now.... I've phoned a couple of places and have been told that no it doesn't have a fuel pump as the vacuum line is doing that job..... another place has said that if the bottom of the tank is above the level of the carbs then it doesn't need a fuel pump.
I've been told where the pump would be located, so there should be a multiplug around the area where it should have been. I've also been told (by a lecturer) that if it should have a pump but doesn't it will affect the top speed and cause poor running at speed.
I've also been told that because it doesn't have the standard can on there it isn't getting enough back pressure and that is affecting the top speed (but allegedly 35mph.... seriously?).
Looking for information on this has thrown up a site that said it was only '95 and afterwards that had fuel pumps......
And Weasley.... do you honestly think I would pay anywhere near that for a fuel pump? I'll just find one second hand if I do need 1.
Ma heed's gonnae explode  |
| davebike |
 Posted: 16:59 - 26 Mar 2015 Post subject: |
Honda part list shoes fuel pump for 1992 CBR600F
Symptoms match lack of pump
Pump hard to mend and expensive to replace
If previous owner only used it at low speed / fairly full tank he not be bothered ____________________ Dave
| mysterious_rider |
The last post was made 11 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
