| tomaha |
 tomaha L Plate Warrior
 Posted: 13:03 - 26 Mar 2015 Post subject: Kawasaki ER5 won't start |
First of all - hi there, to all you bikers out there. I've decided to post my problem here, as you seem to be serious about sorting others problems, which I cannot say about forums in Poland.
Anyway, the case is not obvious. I've got a 2000 Kawasaki ER5, which I'm really attached to and I don't consider getting rid of it. I've got various problems with it over last years, but more or less, the bike was in working condition. I've had some problems with the starter not being able to take a full turn, but that has been solved. Yet another issue had surfaced.
When I press the starter button, there comes a series of random clicks from the relay on the right side of the battery. It's quite random with no distinguishable pattern of clicks and silence. It's accompanied by no, or very limited starter movement, and an overflow of gasoline coming out of the engine block. When i hold the button over 3 seconds, the insulation on the wiring starts to melt and burn. The spark plugs are quite new, with no more than 500 km of use.
All in all, the bike is resistant to do anything aside from burning itself and spurting gasoline, which leads to a dangerous combo. I'd be glad for any help you can provide me with.
Cheers |
| MarJay |
 MarJay But it's British!
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 13:39 - 26 Mar 2015 Post subject: |
A friend of mine, with the same bike, had similar problems.
Not so much the electrical side, but difficulty starting, and massive fuel overflow, when trying to start.
The fuel problem was eventually solved with many, very, thorough inspections and cleaning of the carbs.
There was a tiny split in one of the carb diaphragms, just where the lip of the diaphragm fits into the groove on the carb body, very difficult to spot.
This was leading to excess fuel getting into the engine oil and the air box, via the crankcase breather.
Check your engine oil for petrol contamination! ____________________ "Everybody needs money, that's why they call it money!"  |
| Val |
 Val World Chat Champion
| bikenut |
 bikenut World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 16:35 - 26 Mar 2015 Post subject: |
Sounds like the classic er5 Hydro-lock
Carbs flood into engine engine will not turn
Wiring gets hot etc etc
Pull the plugs and try to spin motor
I bet it turns just fine but you get a shower of fuel !!
Oil level will be very high fuel in oil
You probable got a stuck vacume tap
and sticky float valves ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| misscrabstick |
 misscrabstick Crazy Courier
| davebike |
 Posted: 08:17 - 27 Mar 2015 Post subject: |
My experience with several ER5's with the problem is it is mainly the tap sticking sort that and they work
I resorted to an in line manual tap a few times the repair kits don't fix the tap for long and taps are either ££££ or in as bad nick ____________________ Dave
The last post was made 11 years, 13 days ago. Instead of replying here, would creating a new thread be more useful? |
