Kawasaki ER5 won't start
tomaha
PostPosted: 13:03 - 26 Mar 2015    Post subject: Kawasaki ER5 won't start Reply with quote
First of all - hi there, to all you bikers out there. I've decided to post my problem here, as you seem to be serious about sorting others problems, which I cannot say about forums in Poland.
Anyway, the case is not obvious. I've got a 2000 Kawasaki ER5, which I'm really attached to and I don't consider getting rid of it. I've got various problems with it over last years, but more or less, the bike was in working condition. I've had some problems with the starter not being able to take a full turn, but that has been solved. Yet another issue had surfaced.
When I press the starter button, there comes a series of random clicks from the relay on the right side of the battery. It's quite random with no distinguishable pattern of clicks and silence. It's accompanied by no, or very limited starter movement, and an overflow of gasoline coming out of the engine block. When i hold the button over 3 seconds, the insulation on the wiring starts to melt and burn. The spark plugs are quite new, with no more than 500 km of use.
All in all, the bike is resistant to do anything aside from burning itself and spurting gasoline, which leads to a dangerous combo. I'd be glad for any help you can provide me with.
PostPosted: 13:15 - 26 Mar 2015    Post subject: Reply with quote
Sounds like the starter solenoid is at fault. Apparently you can bridge it with a screwdriver to override it temporarily on some models. I'm not sure about the ER5, but it seems likely.
If you've got fuel overflowing, clicking and hot wiring, I'd say that a starter solenoid problem seems a likely culprit. The starting process pumps fuel into the carbs, but because the solenoid is not engaging the starter motor is not turning. I'm guessing that the solenoid not fully engaging puts load on the wiring causing the burning you mentioned.
Suntan Sid
PostPosted: 13:39 - 26 Mar 2015    Post subject: Reply with quote
A friend of mine, with the same bike, had similar problems.
Not so much the electrical side, but difficulty starting, and massive fuel overflow, when trying to start.
The fuel problem was eventually solved with many, very, thorough inspections and cleaning of the carbs.
There was a tiny split in one of the carb diaphragms, just where the lip of the diaphragm fits into the groove on the carb body, very difficult to spot.
This was leading to excess fuel getting into the engine oil and the air box, via the crankcase breather.
Check your engine oil for petrol contamination!
Val
PostPosted: 14:10 - 26 Mar 2015    Post subject: Re: Kawasaki ER5 won't start Reply with quote
That means your solenoid sends plenty of juice, but there is shorting somewhere hence the melting. I have the feeling your starter needs repair.
There is very simple test to find out is there circuit faulty.
To check the ground starter circuit turn your multimer to resistance and connect the black lead to the battery negative contact and the red lead to your starter ground wire connection on the starter itself or touch the starter body. When you turn the ignition switch it should show 0 oms. That will mean your ground circuit is fine.
Do the same for the other the live circuit. Keep your multimer to resistance and connect the red lead to the battery positive contact and the black lead to your starter plus live wire connection on the starter itself. When you turn the ignition switch it should show 0 oms. That will mean your live circuit is fine.
I think in your case both tests will show 0 ohms which will mean all circuits including the solenoid are fine and the issue is in the starter itself. You can repair it or buy a new one.
bikenut
PostPosted: 15:22 - 26 Mar 2015    Post subject: fuel Reply with quote
from where exactly does the fuel come from....an overflow form the carb or elsewhere.....you know of cmnsl which will be of benefit to you....there may also be a manual on here.......
the clicking is probably a bad connection on the starter relay or solenoid ( same just a different name ) , battery, stater motor connection or even a earth bad connection.
the lead getting hot and burning is an other issue, may be a bad connection.......are you sure you sorted the starter motor properly or is there a short circuit inside it......?
are you sure the engine cylinder is not filling full or fuel and causing a hydraulic lock??????
on the next try, with no success, remove the spark plug and kill the ign...turn engine over by hand or put in gear and push the bike....does liquid fuel come put the plug hole.......if engine overchoked, the plug will be wet/black and no liquid fuel ( or very little liquid ) will be present....but if liquid fuel is present then maybe the engine is flooding.........how is the air filter.
nuts about bikes
davebike
PostPosted: 16:35 - 26 Mar 2015    Post subject: Reply with quote
Sounds like the classic er5 Hydro-lock
Carbs flood into engine engine will not turn
Wiring gets hot etc etc
Pull the plugs and try to spin motor
I bet it turns just fine but you get a shower of fuel !!
Oil level will be very high fuel in oil
You probable got a stuck vacume tap
and sticky float valves
Dave
NC750Xdct + others at work !
davebike1@gmail.com
misscrabstick
PostPosted: 17:58 - 26 Mar 2015    Post subject: Reply with quote
I agree with Dave, carb issue is causing an engine full of fuel and hydraulic locking to the extent that the starter can not compress it and rotate the engine, perhaps the float needles, seats and o rings need looking at?
davebike
PostPosted: 08:17 - 27 Mar 2015    Post subject: Reply with quote
My experience with several ER5's with the problem is it is mainly the tap sticking sort that and they work
I resorted to an in line manual tap a few times the repair kits don't fix the tap for long and taps are either ££££ or in as bad nick
Dave
davebike1@gmail.com
The last post was made 11 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 59.92 Kb
