Power routing for helmet camera
Albigularis
PostPosted: 14:37 - 27 Mar 2015    Post subject: Power routing for helmet camera Reply with quote
So I'm fed up of always having to charge my helmet camera, so I'm planning to fit a relay to the bikes battery and then have power for a Sat Nav going up to near the clocks, and then have another power cable onto the relay, for the camera.
I don't want it up at the clocks, because it'll end up swaying around scratching the paint on the tank. Likewise I don't want to step off the bike forgetting it's there and accidentally pulling the camera off my helmet. I do need it to be somewhat weatherproof as well, but I think that can be sorted quite easily.
Has anyone done this? If so, where did you route the cable to?
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
Iain.
PostPosted: 17:40 - 27 Mar 2015    Post subject: Reply with quote
Had the charger under the seat.
When off the bike I simply put the camera on charge, figured it wasnt going to suck that much power. Worked great, when I got back to the bike I swapped my phone over and put that on charge whilst I used the camera. Thumbs Up
Albigularis
PostPosted: 17:55 - 27 Mar 2015    Post subject: Reply with quote
The problem is that on 720p the camera only lasts about 3 hours - on 1080p it will barely manage over 2 hours. As it's on the GS, I plan to do longer rides and my commute to work and back takes about 2 hours, so if I forget to charge it fully the night before, I'm screwed.
PostPosted: 19:02 - 27 Mar 2015    Post subject: Reply with quote
Huh. I'd assumed that someone would be selling a universal magnetically coupled USB cable, but no luck. They're all device specific (Sony Xperia, Pebble watches). Seems like a gap in the market.
Albigularis
PostPosted: 20:00 - 27 Mar 2015    Post subject: Reply with quote
Rather than magnetically coupled, I just realised, I could use a coiled one like this. Which I could attach near the right hand switchgear. Alternatively I could put it under the seat, that would cover the weatherproofing and allow me to pull it out when I need it.
PostPosted: 20:45 - 27 Mar 2015    Post subject: Reply with quote
Nice one, that looks great.
talkToTheHat
PostPosted: 02:22 - 28 Mar 2015    Post subject: Reply with quote
You can get two pole magnetic couplings off of eBay. Use to make connections between +5v and GND connections of your USB. Try cutting up a USB A extension cable?
Edit: called MagCode, is expensive though.
Bandit. does. everything.
PostPosted: 11:00 - 28 Mar 2015    Post subject: Reply with quote
I know, where all the Chinese copies be at?
rideslikean00...
PostPosted: 14:09 - 28 Mar 2015    Post subject: Reply with quote
I'll be looking into a front mounted camera soon, can it be powered from the bike in such a way that it only works when the key is in? So it's not sapping the battery when it's off, although presumably it's not gonna be using a lot of power either way.
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
Albigularis
PostPosted: 17:16 - 28 Mar 2015    Post subject: Reply with quote
Yeah, you fit a relay between the usb cable and the battery, and connect the relay to something that only comes on when the ignition is switched on, like a numberplate light.
I got a relay and a 3-cigarette lighter multi socket thing with 2 usbs on it for a fiver today, so I'll put those in and test later, then all that's left is the USB cable for the camera. I'll cover the adapter in silicone sealant as well, to weatherproof it.
The last post was made 11 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.63 - MySQL Queries: 13 - Page Size: 71.6 Kb
