Derbi Senda 50cc Two stroke, water cooled ISSUE
Deckers56
PostPosted: 20:48 - 29 Mar 2015    Post subject: Derbi Senda 50cc Two stroke, water cooled ISSUE Reply with quote
I have owned this bike for around a week now... It has a brand new engine.... Overtime i turn it off there is a LOT of pressure in the coolant container. IT sometimes just bogs out when riding too! I was riding home, the lights began to fade so i went down a gear, it did the same again until i got into neutral and stalled... I have No idea what is wrong! Im thinking it is fuel starvation... Thank you all in advance
Declan
salem1987
PostPosted: 21:00 - 29 Mar 2015    Post subject: Reply with quote
Sounds like head gasket failure. Letting the compression of the engine into the cooling system.
Any white smoke when its running?
Does the coolant bubble pretty violently with the cap off when its running?
Deckers56
PostPosted: 22:12 - 29 Mar 2015    Post subject: Reply with quote
There is a little bit of smoke when first started, but then instantly after ten seconds goes to no smoke and sounds normal! When stopped I hear the gas coming from the coolant case
Declan
Deckers56
PostPosted: 22:13 - 29 Mar 2015    Post subject: Reply with quote
Will start it up tomorrow to check if it bubbles without the cap on
Deckers56
PostPosted: 07:50 - 30 Mar 2015    Post subject: Reply with quote
Started bike this morning, tiny tiny bit of smoke, no bubbles in liquid coolant
Declan
Taught2BCauti...
PostPosted: 08:16 - 30 Mar 2015    Post subject: Reply with quote
Almost certainly head gasket.
Check the oil - often when a head gasket fails, water can find it's way into the oil as well.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 10 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 44.77 Kb
