| rk8479 |
 rk8479 Two Stroke Sniffer
| MarJay |
 MarJay But it's British!
| rk8479 |
| Az |
 Az World Chat Champion
 Posted: 08:52 - 31 Mar 2015 Post subject: |
| rk8479 |
| b422063 |
 b422063 Crazy Courier
| rk8479 |
| b422063 |
| carlosvalderr... |
 carlosvalderr... Two Stroke Sniffer
 Posted: 10:37 - 31 Mar 2015 Post subject: |
When I've not had a stand capable of doing it, I've jacked up the bike via the lower rear RH corner of the frame. Use a rag or similar to protect the paint/ally from the jack pad.
This usually lifts the bike so it rests on the front wheel, sidestand and the jack. Although if the frame is a funny shape, or the bike is particularly arse heavy, it may rest on the rear wheel, and be of no use to you.
It's not the most stable of structures, but it works if your stand/lift is otherwise engaged, packed while moving house or what not.
Break off the torque on the mounting bolts before you jack it, as the bike is more stable on its wheels. Stick the steering lock on, jack it up until the rear wheel just clears the floor, unscrew the bolts, drop the rear tyre and remove the shock.
If you have a willing assistant they can help support the bike, just in case... |
| rk8479 |
 Posted: 13:33 - 31 Mar 2015 Post subject: |
| carlosvalderrama wrote: | When I've not had a stand capable of doing it, I've jacked up the bike via the lower rear RH corner of the frame. Use a rag or similar to protect the paint/ally from the jack pad.
Does it keep balance when on a jack? i feel it might just fall over? |
| P.addy |
 P.addy Red Rocket
| rk8479 |
| MarJay |
| P.addy |
 P.addy Red Rocket
| rk8479 |
| rk8479 |
| Iain. |
 Iain. Could Be A Chat Bot
 Posted: 15:12 - 31 Mar 2015 Post subject: |
| carlosvalderr... |
| Az |
| Iain. |
| KLR600 |
 KLR600 World Chat Champion
| P.addy |
 P.addy Red Rocket
| rk8479 |
| KLR600 |
| Major Doss |
 Major Doss Traffic Copper
The last post was made 11 years, 101 days ago. Instead of replying here, would creating a new thread be more useful? |
