Sticky throttle
Jrod
Page 3 Girl
PostPosted: 19:48 - 27 Jan 2005    Post subject: Sticky throttle [HELP!] Reply with quote
Hi,
My throttle will stick if i open it up all the way, It will unstick after a second. Its not the grip of the throttle itself.
Cable? I dont know help me. Thumbs Up
Cheers.
PostPosted: 20:45 - 27 Jan 2005    Post subject: Reply with quote
One of the cables being trapped somewhere is probably the most likely cause. Disconnect the return cable (of fitted) and see if it still sticks. Also check the visable bits of the cable at each end for any signs of fraying.
simon1221
PostPosted: 21:53 - 27 Jan 2005    Post subject: Reply with quote
I guess you have checked inside the throttle box thingy.
Try spraying in some WD-40 down the cable and see if you can unstick some corrosion somewhere.
Also look at the divider box (if you have one on zxr's?).
Jrod
Page 3 Girl
PostPosted: 12:16 - 28 Jan 2005    Post subject: Reply with quote
I will have a look sometime tonight, at first I thought it was the grip because it only did it at full throttle but when I took it apart I saw it wasn't.
Rift.
PostPosted: 12:43 - 28 Jan 2005    Post subject: Reply with quote
Have you tried oiling the cable??
That helped on my cables!!
Make a funnel and pour oil down through the funnel and leave over night...
You only live once so get a bike and ride
loply
PostPosted: 11:50 - 30 Jan 2005    Post subject: Reply with quote
What kind of oil?
I also get this exact same thing. It only sticks when its completely open, and after 4-5 seconds usually unsticks by itself.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Claud 14.7 to 1
PostPosted: 13:30 - 30 Jan 2005    Post subject: Reply with quote
Engine oil. You don't need a lot, and you will know when the cable is fully oiled because oil will be coming out of the other end.
Hang them up vertically, and let gravity help you. Cool
PostPosted: 13:35 - 30 Jan 2005    Post subject: Reply with quote
Problem of using oil is that some cables have a nylon liner and this will expand when exposed to the oil. This will make the cable stiffer and more prone to sticking.
Dom_
Points Mean Prizes
PostPosted: 16:30 - 30 Jan 2005    Post subject: Reply with quote
What about wd40, will that have the same effect on the nylon liner?
BLOFLY 636
PostPosted: 19:11 - 30 Jan 2005    Post subject: Reply with quote
I have seen the cable pressure packs for sale here, you just screw one end of the cable on to the nozzle of the spray and give it a squirt for a couple of seconds and your done! nice quick clean and easy I think it is a silicone based spray
Those bloody footpegs......they ought to do away with em!
PostPosted: 19:39 - 30 Jan 2005    Post subject: Reply with quote
Same effect. Basiscally for these cables (and it is not all cables by a very long way) avoid anything oil based. Use something like a graphite lube.
The last post was made 21 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 69.21 Kb
