Fitting exhaust honda cbr 125 2008
rclacko
PostPosted: 13:18 - 31 Mar 2015    Post subject: Fitting exhaust honda cbr 125 2008 Reply with quote
Hi, first of all apologies if i'm breaking any forum rules or posting this in the wrong section, this is my first time posting.
Secondly, i know next to nothing about bikes...
Basically i've bought a new downpipe for my bike, i've removed the old one (that looked like it would crumble into dust any second); i just can't seem to remove this final piece from the manifold (see attached picture, outlined in red). I assume this must be removed as the new downpipe i have bought has this same piece welded on. Is it just stuck on because it's so rusty or is it attached with something?
Any help is greatly appreciated
PostPosted: 18:19 - 31 Mar 2015    Post subject: Reply with quote
Bizarro. It looks like the crud has become structural. Get in there with a wire brush and clean the heck out of it?
Thumbs Up for awesome picture.
zark
PostPosted: 10:27 - 01 Apr 2015    Post subject: Reply with quote
Is that the remains of the gasket? Can it just be broken up and pulled out? But yeah - wire brush will either shift it or let you see what you're dealing with.
Diagram here shows there should only be a flange (that's loose on your new downpipe?) that slots onto those 2 studs with a gasket inside?
davebike
PostPosted: 11:33 - 01 Apr 2015    Post subject: Reply with quote
Looks more like the end of the old exhaust is stuck in the head !!
Dave
NC750Xdct + others at work !
davebike1@gmail.com
PostPosted: 11:41 - 01 Apr 2015    Post subject: Reply with quote
This is what I'd probably do. If you can get some of the structural crud out of the way and cleaned up your problem will become clearer and you can work out how you'll get the rest of the exhaust out.
PostPosted: 11:54 - 01 Apr 2015    Post subject: Reply with quote
Yup. Had that happen on a Hyosung GT125; we ended up taking the head off in order to get enough room to drill and chisel it out. Brick Wall
Even so, it didn't look as bad as that.
rclacko
PostPosted: 19:56 - 01 Apr 2015    Post subject: Reply with quote
thanks for all the help so far everyone. ive been applying some 3in1 penetrant to it, i read on some other forums that could help loosen it. i applied it twice yesterday then once again today and had another go at removing it. i tried wedging something inside and tried to work it out and i also tried the delicate approach of hitting it with a hammer as someone on another site suggested lol. it still wont budge. i'm going to get a wire brush and then try applying more penetrant, hopefully by brushing it it'll clean it up a bit to allow the penetrant to get in and do its stuff.
Also can someone confirm that it is the entire piece i highlighted in red that should be removed from the manifold? as in what appears to be the (header?) of the downpipe that's snapped off? i assumed so as that part is welded on to the new downpipe i bought (see attatched picture)
thanks again for the responses.
Nemo
PostPosted: 20:35 - 01 Apr 2015    Post subject: Reply with quote
If you have/know someone with a blowtorch you could try getting it bloody hot.... then try smack it out.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
CBRMAN94
PostPosted: 10:22 - 04 Apr 2015    Post subject: Reply with quote
Had this more than once! Verrrrryyyy common on CBR125s. I struggled for a while but the best thing i found to do is to cut a slot with a dremel type tool through it and then give it a good whack with a chisel and a big hammer. The second you've broken the corrosion away it'll pop out in seconds
Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR
Taught2BCauti...
PostPosted: 08:27 - 05 Apr 2015    Post subject: Reply with quote
I would try to cut slots in it with the end of an hacksaw blade - top and bottom, left and right - then use a small cold chisel or centre-punch to try and tap the quarters inwards.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
The last post was made 10 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 64.9 Kb
