dun goof'd
EazyDuz
PostPosted: 15:00 - 06 Apr 2015    Post subject: dun goof'd Reply with quote
Hadnt ridden in 2 weeks. Went to fire her up and the batteries dead.
Alarm probably sucking the life out of it, i have no idea how old the battery is either.
Have a Halfords tender hooked up, 1.25 amps. Can i kiss goodbye riding today?
Would it harm the bike to leave the charger hooked up and attempt starting it as a sort of boost?
CaNsA
PostPosted: 15:02 - 06 Apr 2015    Post subject: Reply with quote
go buy another battery Thumbs Up
25% off in store purchases through quidco.
Acemastr
Tried bumping it? you'd need a long ride with no headlight on to get charge back into it.
2016 Toyota Tacoma Limited
dydey90
PostPosted: 15:34 - 06 Apr 2015    Post subject: Reply with quote
I wouldn't try starting it up with the charger attached unless you use a nail for a fuse.
Give it a couple of hours on charge and it should get it away, depending on the charger, the battery, mechanical state of the bike and all that jazz.
Skudd
PostPosted: 15:39 - 06 Apr 2015    Post subject: Reply with quote
Jump it from another vehicle, then go for a loooooooooooooooong ride.
EazyDuz
PostPosted: 16:56 - 06 Apr 2015    Post subject: Reply with quote
Got it going after about an hour and a half on the charger. Rode about 30 miles, now the weathers better i shouldnt need the tender very often.
Chuffin Nora
PostPosted: 17:08 - 06 Apr 2015    Post subject: Reply with quote
Bungee a petrol generator to pillion seat.
Plug-in charger.
Away you go!
There's a fine line between integrity
doggone
PostPosted: 17:09 - 06 Apr 2015    Post subject: Reply with quote
You might find it goes flat quicker now it's been fully discharged - lead acid don't like it when they are getting older anyway.
onefourk
PostPosted: 21:12 - 06 Apr 2015    Post subject: Reply with quote
And try not to stall it Very Happy
talkToTheHat
PostPosted: 08:11 - 07 Apr 2015    Post subject: Reply with quote
You still riding a 535? I caught mine doing this at one point, realised the key was worn and was coming out with the ignition still on. Switched to the pristine spare key, all good. Took lock off and gave it a proper clean. I think it had been sprayed with an oil that polymerised a bit and went gummy.
Bandit. does. everything.
skatefreak
PostPosted: 09:54 - 07 Apr 2015    Post subject: Reply with quote
Can you not just bump it and off you go or is that just old carbed bikes?
Does it not work for modern fuel injected bikes etc?
Took the battery completely out of one of my bikes at one point, didnt cause any problems...
Never had anything new enough for FI... wouldn't know Neutral
-Jvr
temeluchus
PostPosted: 12:33 - 07 Apr 2015    Post subject: Reply with quote
Never understood the insane obsession with not spending money on batteries some people have. Not like the bike starting is important I guess?
PostPosted: 12:36 - 07 Apr 2015    Post subject: Reply with quote
-Jvr
Tried to bump start my wifes ER6. It did not like it at all. Dead batterys and electronics do not mix well!!
EazyDuz
PostPosted: 16:42 - 07 Apr 2015    Post subject: Reply with quote
Used bike didnt know how old battery waz
Orennayar
PostPosted: 22:31 - 07 Apr 2015    Post subject: Reply with quote
My battery went flat after a week away with the alarm on, I bought a 20 quid car battery charger and plugged the battery on for an hour which was enough to start the bike without problems after. Thumbs Up
DAS passed: 21/07/14
2011 YBR125(sold)
2009 XJ6N
DRZ4Hunned
PostPosted: 23:33 - 07 Apr 2015    Post subject: Reply with quote
Same thing happened to me on my DRZ, was fitting a new tail light, kept testing to make sure it all worked and when I went to start it, it wouldn't go… Was just when the weather started to turn nice as well, bought a charger, didn't arrive until I finally managed to bump start it Evil or Very Mad
DRZ400-SM
FZS600
PostPosted: 08:30 - 08 Apr 2015    Post subject: Reply with quote
That. I stuffed the electronics on my Citroen by trying to start it with a ropey battery. Do not risk.
EazyDuz
PostPosted: 09:06 - 08 Apr 2015    Post subject: Reply with quote
Dont know whether to go for a Motobatt of Yuasa. Motobatt is maintenance free and boasts higher CCA but some reviews are mixed. I remember mine lost power on the 535 quite quickly when i had heated grips fitted (even when they were off, still drew power). But then the 535's charging system was weak at best.
The last post was made 11 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 94.51 Kb
