How to remove rounded hex bolts? (with pics)
Gazz
PostPosted: 19:52 - 08 Apr 2015    Post subject: How to remove rounded hex bolts? (with pics) Reply with quote
Tonight I managed to round an internal hex bolt on the front brakes. The bolt is just really a cover for the actually bolts which undo the caliper.
Any suggestions on how to remove it?
Rounded one
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-xtp1/v/t1.0-9/11150168_10153170228537768_4531573149576055931_n.jpg?oh=2fa6648cb9ed41cf13fc1e8e4e850594&oe=55A96A4E&__gda__=1436710283_f7611352887a360e06b631966f8e7932
The one that did remove without any issues.
https://scontent-lhr.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/1896780_10153170231082768_489513299246121712_n.jpg?oh=790fcfc780da523d9772241211f0236d&oe=55AA32B1
The thing that came out (and needs to come out the other one)
https://scontent-lhr.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/11012676_10153170228807768_5579754199318174677_n.jpg?oh=4c7416530d1defa6e3e99e18d8b4f99c&oe=55ADF00B
A100man
PostPosted: 19:57 - 08 Apr 2015    Post subject: Reply with quote
If you're not in a hurry 1st soak with plus gas. If you are then heat it up as much as you can (avoiding overheating rubber seals) and tap it round with a centre punch. also try banging it square on with a drift first to shock it.
PostPosted: 20:05 - 08 Apr 2015    Post subject: Reply with quote
As usual, left threaded drill bit. The plug is toast anyway, the drill will have it out in no time.
Acemastr
PostPosted: 20:07 - 08 Apr 2015    Post subject: Reply with quote
Cut a slit in each side and use a flat head screwdriver
2016 Toyota Tacoma Limited
ADSrox0r
PostPosted: 22:46 - 08 Apr 2015    Post subject: Reply with quote
https://www.amazon.co.uk/HeroNeo%C2%AE-Screw-Extractor-Broken-Remover/dp/B00RB1A48O/ref=sr_1_5?ie=UTF8&qid=1428529500&sr=8-5&keywords=bolt+remover
Piece of piss
BanditsHigh
Worse than a woman
PostPosted: 09:23 - 09 Apr 2015    Post subject: Reply with quote
Usual method is to hammer in an oversize torx bit ... it should cut grooves into the side of the head and allow you to get it out.
The other way is to weld a nut on to the head.
If you get stuck, you could drop by with the caliper and I can weld a nut on Thumbs Up
All the best ... Barry
PostPosted: 09:34 - 09 Apr 2015    Post subject: Reply with quote
ADSrox0r wrote:
If the bit he's trying to remove is seized enough to round off it could well be seized enough to snap an easy out in place leaving him with even more of a problem.
gl0ckage
PostPosted: 10:41 - 09 Apr 2015    Post subject: Reply with quote
JB Weld + Something thats fits inside you can rotate.
+ Shock & unlock spray or plus-gas w/e brand you want.
GS500 Custom - GS500 Standard X2 - ZX9R C1
Gazz
PostPosted: 19:32 - 10 Apr 2015    Post subject: Reply with quote
Tried the oversized torx bit. Tried drill in reverse. Tried cutting slots in the sides and using screwdriver but none of the above seem to have worked.
Unsure of the welding option because the bolt is less than 10mm in diameter and the area I would need to weld would be very small.
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xfp1/v/t1.0-9/11150605_10153174999212768_8675847052592231370_n.jpg?oh=72b39f5025b28fb6f274ee7c5adea1ff&oe=55E24138&__gda__=1436165725_f5c6902867ddb480e9857ab1420ba8bd
And I worry that I will end up welding something to the surface of the caliper by mistake.
Here is the state of the bolt now:
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-xaf1/v/t1.0-9/11149526_10153174999362768_2318444121953842491_n.jpg?oh=dfaa22e66ca290afeb84768159fd1e0c&oe=55A89821&__gda__=1441120917_8d399e4598b899e370b0407bc509a476
Any other advice?
Gazz
PostPosted: 19:35 - 10 Apr 2015    Post subject: Reply with quote
P.S - I only have a stick welder so accuracy would be worse than if I had a welder that used wire. The welding rods are probably thicker than the small section of bolt that I would need to weld onto.
Matt B
PostPosted: 20:23 - 10 Apr 2015    Post subject: Reply with quote
Second hand caliper may be easier?
Gazz
PostPosted: 20:45 - 10 Apr 2015    Post subject: Reply with quote
ADSrox0r wrote:
Just bought these, for £3, we'll see if they work with what is left of the bolt. If not, then they will come in handy for a future job I am sure.
The only problem is, the delivery time is another 2 weeks at the earliest!!!!!!!!!! Shocked
A100man
PostPosted: 21:00 - 10 Apr 2015    Post subject: Reply with quote
Any other advice?
Well drill in reverse isn't going to be any good with out a reverse (left hand) action drill bit. cutting slots was also going to be anon-starter IMO - just can't apply enough torque before you b*gger up the tiny slots you can manage to create.
You don't say if you tried soaking in penetrating fluid and tapping it around with a punch as was also suggested..
Robby
Dirty Old Man
PostPosted: 21:02 - 10 Apr 2015    Post subject: Reply with quote
You said you tried drill in reverse - were you using a left-handed drill bit, or just trying to spin a normal bit backwards?
stirlinggaz
PostPosted: 21:04 - 10 Apr 2015    Post subject: Reply with quote
hi,
cobalt drill bits. buy a set of 4 or 5 or singly, your choice.
i have them as small as 1.5mm up to 10mm (one of the best investments in last 5yrs btw) but in this instance, you might get away with just 4mm, 6mm & 8mm bits.
drill slow, with a bit of pressure, pushing downwards & keep the drill bit cool, this is vital. i spray it with wd40 with the wee red straw, simply because im a cheap-skate, so get it from poundland Cool (one of the few times wd40 is better than plus-gas)
the propellant in the aerosol cools the bit. the active ingredient cleans & lubes it slightly.
i then add a drop or 2 of 3-in-1 oil, from the wee plastic bottle (non aerosol) using it as a cutting oil (for same cheap-skate reasons as wd40 Wink )
start by getting the caliper in a vice & hit it with a hammer & punch, as close to the centre of the bolt as you can, then use the smallest drill bit & work your way up in size till the bolt collapses on itself.
at 1st you will think your getting nowhere, but keep with it. short bursts on the drill, as slow as possible till it starts to bite, then back out.
cool & clean. repeat over & over til your through the head.
when backing out, turn the drill into reverse, sometimes it will unscrew the bolt if it has enough of a bite/grip on the bolt head but if it doesnt, it WILL collapse on itself or turn to swarf eventually.
pick out the remnants of the bolt with something sharp & pointy, blow all the remaining debris with an air-line then tidy up the threads by running a tap down it.
15mins work.
done this myself a few times today, i have had to drill out 2 x M4 master cylinder bolts (the usual jis/phillips screw confusion by a po Rolling Eyes ) & 1 big hex head M8 caliper bolt using this very same method.
why cant people use the correct tools & treat the bolts to the correct lube or thread lock?
then they screw it up tight,too tight (no torque wrench?) even though theres a bloody good chance a future owner is gonna have to go through all this sh*t.
good luck!
cheers,
GAZ
Fisty
PostPosted: 21:19 - 10 Apr 2015    Post subject: Reply with quote
BodyGuard wrote:
Twat a slit into it and work it out with a punch and hammer.
Says the fountain of knowleage.
Fatter and faster than Fret
Fisty
PostPosted: 21:26 - 10 Apr 2015    Post subject: Reply with quote
BodyGuard wrote:
Yes I am I had a similar experience with a grub screw on my Daelim.
Forgive me but I'd rather stick a screwdriver up my arse sideways than follow your advice. That wants drilling out to the core size and a bottoming tap winding down the threads.
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
webhead
PostPosted: 23:42 - 10 Apr 2015    Post subject: Reply with quote
chuck in bin and buy another secondhand one , and as it will be off make sure all the bits come apart and copper grease it then put it back on , simple why bodge something that saves your life?????
PostPosted: 00:39 - 11 Apr 2015    Post subject: Reply with quote
BodyGuard wrote:
Twat
Indeed.
PostPosted: 07:12 - 11 Apr 2015    Post subject: Reply with quote
You can't use a screw extractor because it bottoms out against the pin. Not that it would be a good idea anyway.
Knock an old m6 allen key home in it and tack it on with your stick welder. There's no chance of it welding to the caliper you can't weld steel to ally like that. Let it cool a bit before you turn it, don't try it red hot.
Other option is to drill the whole thing out with a 10mm drill. It's just a cap for the pad retainer. Put the pin back in with blue threadlock and fill the hole with hot glue/RTV to keep water out.
Ed Case
PostPosted: 15:50 - 11 Apr 2015    Post subject: Reply with quote
A sharp 'centre punch' ans a lightweight hammer.....works every time.
andys675
PostPosted: 22:18 - 11 Apr 2015    Post subject: Reply with quote
had that problem with some cb350s calipers
drilled them through, leaving the seized bit in as a sort of sleeve, knocked a small chisel into the sleeve and used mole grips on it to turn the chisel and sleeve anti-clockwise and it came out leaving it like new, just needed a new brake pin
saw another bloke with a CB450DX who drilled them through and used huge split pins to hold the brake pads in, looked a bit dangerous to me
The last post was made 11 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 129.79 Kb
