Is me wheel in straight?
Wonko The Sane
PostPosted: 20:27 - 09 Apr 2015    Post subject: Is me wheel in straight? Reply with quote
Just been adjusting the chain tension on the ZZR 600E
I noticed a few weeks ago that the front of the wheel sits closer to the left hand centre stand leg than it does the right hand leg, however the notches on the adjustment show the axle being slightly further back on the right than it does the left (chain side)
Still following?
I do recall adding an extra quarter or half turn to one side and believed this to be the chain side.
How can I check if my wheel is in straight?
Ben90
PostPosted: 20:35 - 09 Apr 2015    Post subject: Reply with quote
You need to get your centre stand aligned Wink
Vernier calipers will do the job (on the wheel)
Yamaha FZ6 S2
Islander
PostPosted: 20:41 - 09 Apr 2015    Post subject: Reply with quote
Simple way? Measure the distance between the centre of the swing arm pivot and the centre of the wheel spindle on each side. If it's square then the distances should be identical.
1198
PostPosted: 20:45 - 09 Apr 2015    Post subject: Reply with quote
Use a long straight piece of wood, hold the bike vertical then place wood alongside rear wheel. Measure gap to side of front wheel. Repeat on other side of rear wheel, measure opposite gap, adjust rear wheel to get the gaps equal.
ws4936
PostPosted: 20:49 - 09 Apr 2015    Post subject: Reply with quote
https://i121.photobucket.com/albums/o216/blacklake/1setup.jpg
If everything seems under control, you're just not going fast enough.
iooi
PostPosted: 21:41 - 09 Apr 2015    Post subject: Reply with quote
Forget the center stand and go by the notches....
Odds on c/s is twisted Rolling Eyes
DrSnoosnoo
PostPosted: 08:37 - 10 Apr 2015    Post subject: Reply with quote
With the ZZR6E, there's a LOT of stuff in the way of the centre stand bolt and the rear axle so you can't get a reliable measure that way, that's what I've found.
I can be quite crap at this, so when my tyre got changed I trusted them to put it on straight, it got MOTd and they use a looong piece of straight metal and they said it was straight.
Now, when I tighten my chain, I just tighten it a quarter turn on each and don't bother looking at the marks. I have looked at the markers since doing my quarter turn and they are even, so perhaps you can slacken the wheel off until the marker is centred on a line on the SA then count the turns on the adjusters to keep it straight.... providing your SA isn't bent, which it shouldn't be.
Wonko The Sane
PostPosted: 10:32 - 10 Apr 2015    Post subject: Reply with quote
It's the feet of the centre stand I was going off the wheel being close to, however I get the feeling the chain side might be straighter and closer to the bike anyway.
My bike did get shunted from behind just under a year ago but it's thought mainly the exhaust took the brunt of the impact.
On the markers I'm half a mark out
Bike feels fine but I think the tyre is rubbing, not sure if on swing arm or on hugger.
The teeth were to one side in the chain on the rear sprocket (towards the bike) and are now about centre in the chain
DrSnoosnoo
PostPosted: 12:03 - 10 Apr 2015    Post subject: Reply with quote
With your hugger/chain cover off you should be able to look down the chain to see if it's straight.
If you are so worried (not saying you're being a pansy), nip down to a garage and ask them to check for you.
I remember your hit, and if your SA is bent, and you have to offset the wheel to compensate, see if you can find out by how much. But I thought all this got checked anyway?
TL;DR Nip into a friendly garage and I reckon for a fiver, they'll straighten the wheel out for you. Friendly garage did this for me when I had the bike for a month.
PostPosted: 12:24 - 10 Apr 2015    Post subject: Reply with quote
That assumes the Swingarm is symmetrical, I don't know but isn't it possible while the wheel is in the center, the swingarm might budge out on the chainside to allow more space for the chain/sprocket?
The last post was made 11 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 66.33 Kb
