tyre chicken stripe
stranger12
PostPosted: 12:20 - 10 Apr 2015    Post subject: tyre chicken stripe Reply with quote
Hi All,
I am trying to build my confidence on cornering again and do drop the bike into corners and lean as much as I feel comfortable.
One question I have though is I am seeing the chicken strips as twist of wrist referred to it most of the times.
Below picture is approximate of how much I get on my tyre. Looking at that how far do you think one can lean without dropping the bike?(picture found on internet )
This may sound stupid but recently I test rode a 1000rr and was very impressed by the lean angle that was on the speedo.
I was doing around 25 degree and not leaning as much in fear of dropping a loaned bike but how much would a fast biker normally lean ?
it can't be 90 degree most certainly Smile
something around 40-50 ?
what happens or what are the indications showing you u have used all of the tyre and about to drop it if leaning any more.
https://www.kawiforums.com/attachments/newbie-corner/517d1197506954-questions-ask-when-buying-new-bike-rear-chicken-strips.jpg
SV650 Red
R6 Red
PostPosted: 12:24 - 10 Apr 2015    Post subject: Reply with quote
Have you even been around a corner? Wink
stranger12
PostPosted: 12:26 - 10 Apr 2015    Post subject: Reply with quote
doesn't look like it by the sound of your post
SV650 Red
R6 Red
chickenstrip
PostPosted: 12:29 - 10 Apr 2015    Post subject: Reply with quote
Did someone call? Shifty
PostPosted: 12:30 - 10 Apr 2015    Post subject: Reply with quote
Just a bit of harmless ribbing, by the looks of that tyre, you have plenty of lean angle left.
chickenstrip
PostPosted: 12:34 - 10 Apr 2015    Post subject: Reply with quote
Don't try to go nuts straight away. Let your confidence build slowly, work on your cornering technique, let it come rather than pushing for it. The main thing is to enjoy your riding, don't allow peer pressure to get you doing something you're not ready for. Eventually, you'll lose those strips completely.
DrSnoosnoo
PostPosted: 12:48 - 10 Apr 2015    Post subject: Reply with quote
But this is the guy who adjusts suspension for most racerists setup for roundabouts. He obviously NEEDS rid of those strips.
As has been said, don't worry about it. Just ride, as experience grows you'll get there. My "strips" are a couple of cm on my ZZR and it's a lardy thing but I just enjoy my riding.
johnsmith222
PostPosted: 12:55 - 10 Apr 2015    Post subject: Reply with quote
Forget about chicken strips, don't have anything to prove and just enjoy riding your bike. Confidence will come with experience. Just concentrate on being smooth and looking through the bend.
UrbanRacer
PostPosted: 13:02 - 10 Apr 2015    Post subject: Reply with quote
Check your tyre pressures, chances are it will be too high. Yes it will change direction quickly but it will feel like you are on a knife edge or nervous when lent over.
On the R1 i run 32psi front and 30 rear, those are cold pressures btw.
Iain.
PostPosted: 13:09 - 10 Apr 2015    Post subject: Reply with quote
Drop rear tyre pressure to around 5psi, then go round a roundabout.
Chicken strips will be gone.
Also, you should be able to lean it this far & I look forward to pics of attempts;
https://www.sportbikes.net/forums/attachments/general-sportbikes/152014d1203882966-world-record-lean-angle-kemics-cccc.jpg
PostPosted: 13:14 - 10 Apr 2015    Post subject: Reply with quote
That is quite low no? I Run 36/40 on the Triple and it feels spot on, any less feels rather slow and unwilling to get a shift on.
Those tyres look rather...used and that massive red spot on the chain looks worrying.
chickenstrip
PostPosted: 13:29 - 10 Apr 2015    Post subject: Reply with quote
Hmmm, yes, same here and all is fine on the Fazer.
finchy95
PostPosted: 13:36 - 10 Apr 2015    Post subject: Re: tyre chicken stripe Reply with quote
A wobbly slipping away feeling usually followed by a loud scraping sound and a good degree of pain.
2005 suzuki van van - Sold. -> 2015 honda cbr 125 r - current bike.
Now's not the time for fear. That comes later.
PostPosted: 13:42 - 10 Apr 2015    Post subject: Reply with quote
Normally at the limit it'll give you a little nudge to say that you're pushing it. If the tyres are good tyres and give lots of feel that nudge will be quite a ways before you crash. If they are Bridgestone BT016's, then you'll just crash.
I'd say you've got a long way to go before you're at risk of crashing through leaning too far.
Supermoto_Fan
PostPosted: 13:46 - 10 Apr 2015    Post subject: Reply with quote
If your tyres are they you aren't leaning at all..
Acemastr
PostPosted: 13:48 - 10 Apr 2015    Post subject: Reply with quote
You'll give up way before the bike does on a corner, highly unlikely for the bike to drop out from under you unless you do something silly like jerk the throttle or hit the brakes... or something on the road.
I found this out by going into a corner way too hot and HAVING to lean it over, braking wasn't an option... bike went around without even a chirp Very Happy
*this isn't the way to do it, but it does show what the bike can do
2016 Toyota Tacoma Limited
Nexus Icon
Has Anyone Really Been Far Even as Decided to Use Even Go Want to do Look More Like?
Greetings from Shitsville!
stranger12
PostPosted: 13:51 - 10 Apr 2015    Post subject: Reply with quote
@Paddy , it isn't mine
I always have ran 38/39 rear and 32/34 front
re angle any thoughts ? curious after riding the 1000rr .
by the way my r6 felt like 125 after the 1000rr test
SV650 Red
R6 Red
PostPosted: 13:52 - 10 Apr 2015    Post subject: Reply with quote
https://4.bp.blogspot.com/-FIayducomeU/UXZk6qDUi_I/AAAAAAAAdmM/_vZBiLrlzOY/s1600/goats-are-like-mushrooms.jpg
weasley
PostPosted: 14:04 - 10 Apr 2015    Post subject: Reply with quote
Marquez often achieves over 55°, pushing towards 60° on some corners. Obviously that's on warm slicks and circuit tarmac.
Image for comparison: orange is 58°, pink is 25°.
Dcwhite1984
PostPosted: 14:12 - 10 Apr 2015    Post subject: Reply with quote
My chicken strips are pretty similar to the ones posted above, but im not gonna beat myself up over it.
I enjoy my riding and as the weather gets warmer and i get back into the swing of things a bit more (5 year break from riding) they will get smaller and smaller.
Mine are so large that even my Mrs, who has no clue about anything bike related, was ribbing me about it the other day!!
Its all harmless banter, lean as much as your comfortable with.
The trick to life is to not get too attached to it.........
stranger12
PostPosted: 14:17 - 10 Apr 2015    Post subject: Reply with quote
will reduce tyre pressure a bit to see how it goes.
I am doing active counter steering by pulling the handle in corner and boy i loved it but also scary as is very agile.
SV650 Red
R6 Red
PostPosted: 14:24 - 10 Apr 2015    Post subject: Reply with quote
Marquez has done, 68degrees, granted he lost the front and picked it up again Laughing
https://i.ytimg.com/vi/BnOor-nx8fg/maxresdefault.jpg
stranger12
PostPosted: 14:40 - 10 Apr 2015    Post subject: Reply with quote
wow , that is just silly amount and not achievable on bumpy road.
SV650 Red
R6 Red
Acemastr
PostPosted: 14:55 - 10 Apr 2015    Post subject: Reply with quote
Is this your R6 or your SV?
Your R6 will lean ridiculous angles (I have no chicken strips on mine currently, running 36psi on the back)
The last post was made 11 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 130.27 Kb
