| Speed |
 Speed Could Be A Chat Bot
 Posted: 15:43 - 10 Apr 2015 Post subject: GSXR 750 inconsistent idle |
Hoping the BCF massive can help me shed some light on this problem. Picked up a 2000 GSXR 750 Y a couple of weeks ago and it seems to have a very inconsistent idle. One minute it’s idling at 1.5k and pulling away from a stand still is fine, no problems. Next minute it’s idling at 1k and sometimes stalls when you pull away. I’m having to over rev and slip the clutch a lot more than if it’s idling at 1.5k and makes setting off a ball ache sometimes. This all alternates between the two. Also throttle repsonsiveness is decreased somewhat when the revs are down to around 1k.
It’s got the standard downpipes (wouldn't mind changing these to some stainless steel jobbies) but has an akrapovic can fitted. I’m guessing that the previous owner has fitted the can and not had it setup properly. So I’m thinking would a dyno run and maybe even a power commander help sort this out? It's just had a service so plugs etc are all fine (well, should be ) ____________________ Current: Suzuki GSXR 750 Y
Former: Kawasaki ZX6R Ninja F3 |
| P.addy |
 P.addy Red Rocket
 Posted: 15:57 - 10 Apr 2015 Post subject: |
I didn't set mine up after the CCC can went on.
Does your FI light come on? Also have you check the air filter. Hassle to get to so likely neglected Standard service is where I'd go, plugs, oil, filters. |
| Speed |
 Posted: 16:01 - 10 Apr 2015 Post subject: |
Thanks Paddy. FI light doesn't come on at all. Will have to see where the air filter is and check that out  ____________________ Current: Suzuki GSXR 750 Y
| Speed |
| Vincent |
 Vincent Banned
| Speed |
| Vincent |
 Vincent Banned
| Speed |
 Posted: 17:52 - 10 Apr 2015 Post subject: |
Not too sure on that Vincent. Will mention it to the guy when i see him tomorrow. All part of the lovely 'process of elimination' method  ____________________ Current: Suzuki GSXR 750 Y
| P.addy |
 P.addy Red Rocket
 Posted: 18:48 - 10 Apr 2015 Post subject: |
I don't think they do. They have a fast idle lever but it's rarely used  |
| Speed |
 Posted: 18:16 - 11 May 2015 Post subject: |
Just a little update. Had the spark plugs changed, air filter changed, throttle bodies balanced, tps set up, ran injector cleaner through but still no joy. Taking it back to Suzuki tomorrow to see if they can fiddle with it some more. Proving to be a real ball ache  ____________________ Current: Suzuki GSXR 750 Y
| andym |
 andym World Chat Champion
 Posted: 20:25 - 11 May 2015 Post subject: |
Check the vac lines for splits, a leak on the map sensor (APS) line can cause rough idle. If nothing else works check your valve clearances, tight clearances can also cause erratic idle. ____________________ a.k.a 'Geri'
| Speed |
 Posted: 10:00 - 12 May 2015 Post subject: |
Could be the pressure regulator, some Suzuki's have a filter in the regulator inlet. Might also be the return hose if it has one. If it happens more when it's hot especially. ____________________ a.k.a 'Geri'
| Speed |
 Posted: 09:16 - 13 May 2015 Post subject: |
Took it to Suzuki yesterday and they checked fuel pressure and fuel filters etc but both were spot on. Plugged the Yoshi box in and changed a few settings. Bikes slightly better but still occasionally drops at idle along with an occasional knocking from the tank. Will probably have to live with it or chuck it up for sale  ____________________ Current: Suzuki GSXR 750 Y
| Speed |
 Posted: 14:40 - 14 Jul 2015 Post subject: |
Update-
Just thought I’d update this thread in case anyone else might have had these issues. After all the buggering about it turns out it was the exhaust can… The garages I took it to said that it wasn’t down to the can or a loss of back pressure. Kept mulling it over and happened to find a standard can on fleabay for £15 and thought it was worth a try. Fitted it anyway and now it runs like dream  ____________________ Current: Suzuki GSXR 750 Y
| Vincent |
 Vincent Banned
| Speed |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 16:06 - 14 Jul 2015 Post subject: |
checked ecu?
injectors all clean? ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| Speed |
 Posted: 16:58 - 14 Jul 2015 Post subject: |
TL:DR  ____________________ Current: Suzuki GSXR 750 Y
| Az |
 Az World Chat Champion
| Pol Anorl |
 Pol Anorl Banned
The last post was made 11 years, 93 days ago. Instead of replying here, would creating a new thread be more useful? |
