GSXR 750 inconsistent idle
Speed
PostPosted: 15:43 - 10 Apr 2015    Post subject: GSXR 750 inconsistent idle Reply with quote
Hoping the BCF massive can help me shed some light on this problem. Picked up a 2000 GSXR 750 Y a couple of weeks ago and it seems to have a very inconsistent idle. One minute it’s idling at 1.5k and pulling away from a stand still is fine, no problems. Next minute it’s idling at 1k and sometimes stalls when you pull away. I’m having to over rev and slip the clutch a lot more than if it’s idling at 1.5k and makes setting off a ball ache sometimes. This all alternates between the two. Also throttle repsonsiveness is decreased somewhat when the revs are down to around 1k.
It’s got the standard downpipes (wouldn't mind changing these to some stainless steel jobbies) but has an akrapovic can fitted. I’m guessing that the previous owner has fitted the can and not had it setup properly. So I’m thinking would a dyno run and maybe even a power commander help sort this out? It's just had a service so plugs etc are all fine (well, should be Very Happy )
Current: Suzuki GSXR 750 Y
Former: Kawasaki ZX6R Ninja F3
PostPosted: 15:57 - 10 Apr 2015    Post subject: Reply with quote
I didn't set mine up after the CCC can went on.
Does your FI light come on? Also have you check the air filter. Hassle to get to so likely neglected Thumbs Up Standard service is where I'd go, plugs, oil, filters.
Speed
PostPosted: 16:01 - 10 Apr 2015    Post subject: Reply with quote
Thanks Paddy. FI light doesn't come on at all. Will have to see where the air filter is and check that out Thumbs Up
Speed
PostPosted: 16:37 - 10 Apr 2015    Post subject: Reply with quote
Just spoke to the guy at the garage i got it from and he says that everything got changed except the plugs but was assured when he bought it from the previous owner that the plugs had been changed last year as it had a full service anyway. I trust him as he’s a really sound bloke. He said that the calipers had copper grease in them so it had been a thorough service anyway. Not too sure if to risk changing the plugs as I believe it may have been stood a couple of months until I bought it.
Speed
PostPosted: 17:37 - 10 Apr 2015    Post subject: Reply with quote
Vincent wrote:
Whats the mileage? Any valve service history?
A tad over 26k. Have phoned a local garage who thinks its the throttle bodies. Will change filter, oil, plugs and balance throttle bodies for £150.
Speed
PostPosted: 17:52 - 10 Apr 2015    Post subject: Reply with quote
Not too sure on that Vincent. Will mention it to the guy when i see him tomorrow. All part of the lovely 'process of elimination' method Laughing
PostPosted: 18:48 - 10 Apr 2015    Post subject: Reply with quote
I don't think they do. They have a fast idle lever but it's rarely used Laughing
Speed
PostPosted: 18:16 - 11 May 2015    Post subject: Reply with quote
Just a little update. Had the spark plugs changed, air filter changed, throttle bodies balanced, tps set up, ran injector cleaner through but still no joy. Taking it back to Suzuki tomorrow to see if they can fiddle with it some more. Proving to be a real ball ache Sad
andym
PostPosted: 19:41 - 11 May 2015    Post subject: Reply with quote
Slap some super unleaded in there and take it for a bloody good thrashing down the motorway.
Again I haven't got a clue what I'm talking about here, so pay no attention to it.... but you said that:
Surely if it was a problem with the pipes, service items, air filter etc then it would be there all the time?
PostPosted: 20:25 - 11 May 2015    Post subject: Reply with quote
Check the vac lines for splits, a leak on the map sensor (APS) line can cause rough idle. If nothing else works check your valve clearances, tight clearances can also cause erratic idle.
Speed
PostPosted: 09:53 - 12 May 2015    Post subject: Reply with quote
Thanks guys, will mention the above when i drop it off with them this afternoon. It's strange how it'll idle at 1500 and then drop down and stutter at 1000 then back up to 1500. I’m thinking maybe a blocked fuel pump filter but wouldn’t that cause a constant rough idle? Plus I feel that it doesn’t have the grunt like it did before hand.
PostPosted: 10:00 - 12 May 2015    Post subject: Reply with quote
Could be the pressure regulator, some Suzuki's have a filter in the regulator inlet. Might also be the return hose if it has one. If it happens more when it's hot especially.
Speed
PostPosted: 09:16 - 13 May 2015    Post subject: Reply with quote
Took it to Suzuki yesterday and they checked fuel pressure and fuel filters etc but both were spot on. Plugged the Yoshi box in and changed a few settings. Bikes slightly better but still occasionally drops at idle along with an occasional knocking from the tank. Will probably have to live with it or chuck it up for sale Confused
Speed
PostPosted: 14:40 - 14 Jul 2015    Post subject: Reply with quote
Update-
Just thought I’d update this thread in case anyone else might have had these issues. After all the buggering about it turns out it was the exhaust can… Rolling Eyes The garages I took it to said that it wasn’t down to the can or a loss of back pressure. Kept mulling it over and happened to find a standard can on fleabay for £15 and thought it was worth a try. Fitted it anyway and now it runs like dream Thumbs Up
Speed
PostPosted: 15:31 - 14 Jul 2015    Post subject: Re: GSXR 750 inconsistent idle Reply with quote
Vincent wrote:
You had it in your first post Wink
I sure did but assumed the can was ok and just needed it set up correctly. Kicking myself now as it should have been the first thing i should have looked at/changed. Laughing
PostPosted: 16:49 - 14 Jul 2015    Post subject: Reply with quote
PaulFzs wrote:
checked ecu?
injectors all clean?
Cabbage for a head?
Speed
PostPosted: 16:58 - 14 Jul 2015    Post subject: Reply with quote
TL:DR Laughing
Az
PostPosted: 17:04 - 14 Jul 2015    Post subject: Reply with quote
Someone on the gsxr owners page on FB had a similar problem with his akra' can. Had it setup on a dyno and its all good now.
Saying that, I have an akra on my 600 k3 & have no issues with idling at all & the bike feels and acts no different to the standard can.
The last post was made 11 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 119.36 Kb
