| Philc |
 Philc Derestricted Danger
 Posted: 17:33 - 10 Apr 2015 Post subject: Old 2 stroke not starting, help please |
Evening all,
So, i have some issues with my little bike, i have trawled the internet and tried to sort it but haven't come close.
The issue is my 2 stroke is not starting (suzuki gp100). Here is the list i have gone through;
It has a spark, blue and strong (i think) and the plug is gapped correctly.
Fuel is getting to the carb, and all the jets are clear, carb is working properly.
Compression is fine, have had the head off and the piston and rings are good. No scoring on the cylinder etc.
From what i can see, there doesnt seem to be much suction to draw fuel and air from the carb and into the engine. The timing is done via a nippon denser pid unit, the stator plate is mounted correctly with all the timing marks lined up so i dont think timing is an issue.
My experience with 2 stroke engines is nil so any help is appreciated. |
| A100man |
 A100man World Chat Champion
 Posted: 20:06 - 10 Apr 2015 Post subject: Re: Old 2 stroke not starting, help please |
| Philc wrote: | Evening all,
What - no points ?? ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
| Philc |
| Teflon-Mike |
 Teflon-Mike tl;dr
| Philc |
| webhead |
 webhead Renault 5 Driver
| A100man |
 Posted: 22:47 - 10 Apr 2015 Post subject: |
| Teflon-Mike wrote: | if you aren't getting much suck through the carb,suggestion is leaks i induction tract and or the crank-case seals are shot. |
As Mike points out CC seals can be a big issue with long standing 2T but I would have thought it would run-ish, gutless but run..
Can you check spark is 2 degs or so BTDC
J ____________________ Now: A100, GT250A, XJ598, FZ750
| Philc |
| A100man |
 Posted: 08:38 - 11 Apr 2015 Post subject: |
| Philc wrote: | | A100man wrote: |
J |
No idea how to check that without a timing light im afraid |
Did I write that after a trip to the pub ? I think I must have meant 2mm. A pencil down the plug hole and watching the spark pluig might be possible to get a rough idea.. ____________________ Now: A100, GT250A, XJ598, FZ750
The last post was made 10 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
