Old 2 stroke not starting, help please
Philc
PostPosted: 17:33 - 10 Apr 2015    Post subject: Old 2 stroke not starting, help please Reply with quote
Evening all,
So, i have some issues with my little bike, i have trawled the internet and tried to sort it but haven't come close.
The issue is my 2 stroke is not starting (suzuki gp100). Here is the list i have gone through;
It has a spark, blue and strong (i think) and the plug is gapped correctly.
Fuel is getting to the carb, and all the jets are clear, carb is working properly.
Compression is fine, have had the head off and the piston and rings are good. No scoring on the cylinder etc.
From what i can see, there doesnt seem to be much suction to draw fuel and air from the carb and into the engine. The timing is done via a nippon denser pid unit, the stator plate is mounted correctly with all the timing marks lined up so i dont think timing is an issue.
My experience with 2 stroke engines is nil so any help is appreciated.
A100man
PostPosted: 20:06 - 10 Apr 2015    Post subject: Re: Old 2 stroke not starting, help please Reply with quote
Philc wrote:
Evening all,
What - no points ??
Philc
PostPosted: 20:38 - 10 Apr 2015    Post subject: Reply with quote
Yep, i believe it was installed by the factory onto later gp125s, however it seems that a previous owner has substituted this in place of the points and condenser.
Following the haynes manual i have tested the ignition circuit as much as possible with a multimeter and it all seems fine.
Teflon-Mike
tl;dr
PostPosted: 21:09 - 10 Apr 2015    Post subject: Reply with quote
if you aren't getting much suck through the carb,suggestion is leaks i induction tract and or the crank-case seals are shot.
Philc
PostPosted: 21:24 - 10 Apr 2015    Post subject: Reply with quote
Cheers, that makes sense. I haven't tried to disassemble the engine as on first inspection the bolts are completely seized and i dont want to have them shear off or round off when i try and undo them.... Unless there is another way i can check the seals.
webhead
PostPosted: 22:37 - 10 Apr 2015    Post subject: Reply with quote
get someone to strip it and put new seals in and crank case , then get some nice new allen bolts make sure its tight , she will fly.
A100man
PostPosted: 22:47 - 10 Apr 2015    Post subject: Reply with quote
As Mike points out CC seals can be a big issue with long standing 2T but I would have thought it would run-ish, gutless but run..
Can you check spark is 2 degs or so BTDC
J
Philc
PostPosted: 08:09 - 11 Apr 2015    Post subject: Reply with quote
J
No idea how to check that without a timing light im afraid
A100man
PostPosted: 08:38 - 11 Apr 2015    Post subject: Reply with quote
J
Did I write that after a trip to the pub ? I think I must have meant 2mm. A pencil down the plug hole and watching the spark pluig might be possible to get a rough idea..
The last post was made 10 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 61.94 Kb
