spraying plastics
stryker
PostPosted: 10:32 - 30 Jan 2005    Post subject: spraying plastics Reply with quote
Guys,
I've got a nose cone to replace the one on my bike (cracked when I binned it).
I'd like to spray the nose the same colour as my bike. Now, can I do this (considering its plastic)? Would a sanding down to remove the laquear and rough the surface be sufficient?
Now what?
Hex
Party Boy
PostPosted: 11:11 - 30 Jan 2005    Post subject: Reply with quote
Yeah just sand the surface so the paint has a surface it can stick to.
How you planning to spray the paint (please dont say cans).
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
jorgedoors
It really depends on what you are going to paint it with! And what colour it is at the moment!
GSXReater
PostPosted: 22:58 - 30 Jan 2005    Post subject: Reply with quote
Is there an 'Idiots guide' of how to do such painting. A guide to help with prep work, painting and laquering?
alains
PostPosted: 00:57 - 31 Jan 2005    Post subject: Reply with quote
i recommand to spray first a special undercoat for plastic , otherwise your paint will crack ang go away
binge
Emo Kiddy
PostPosted: 01:10 - 31 Jan 2005    Post subject: Reply with quote
Halfords paints are good if you use them right.
Sand down your plastic so the paint has a surface to stick to,
Go over with very fine wet and dry to take out the scratch marks of the sand paper,
Apply primer,
Let dry and gently rub with VERY fine wet and dry,
apply more primer,
Etc etc etc.
Do this about 4 times...
Let it dry fully and then you can start applying your paint.
If you are using cans, Be careful of spluttering because they are prone to do it.
Give it PLEANTY of coats of paint. I didnt and Ive Tcut the bike and the grey primer has started to slightly shine through on the back Sad
Then its a case of laquering it up, and polising / buffing.
Geting the colour match will be difficult though, Unless you get it mixed up at a garage, If you do it this way, you will need an airbrush kit...
<|Binge|>
PostPosted: 01:17 - 31 Jan 2005    Post subject: Reply with quote
Might have fun with the flourescent colour. There is a guy in Kingswinford who does bike respray work.
ZRX61
Victor Meldrew
PostPosted: 03:51 - 31 Jan 2005    Post subject: Reply with quote
There are dozens of books on the subject..... & the majority of them completely contradict the clueless fucking replies by so called *painters* on this board. Basically ignore any advice on the subject in this thread... Ya get dumbass comments like:
"Go over with very fine wet and dry to take out the scratch marks of the sand paper,
Apply primer,
Let dry and gently rub with VERY fine wet and dry,"
No fucking hint at what constututes "fine" or "very fine" at all, if the guy doing the paint is familair with woodworking his idea of fine & very fine is gonna be completely fucking wrong for auto paint finishes.
I've posted a few replies on how to do the job correctly on this board several times & ya still get idiots giving backassward advice, ya may as well use a fucking roller..........
kasandrich
PostPosted: 17:09 - 31 Jan 2005    Post subject: Reply with quote
The only cans I've ever had any success with are ones I bought from a specialist car paint supplier, he mixes the paint himself, according to your paint code and then fills these airosol cans, they have a proper fan pattern and the paint is thicker than that from Halfords.
Richard
CBR1000FM
stryker
PostPosted: 20:45 - 04 Feb 2005    Post subject: Reply with quote
Thanks guys. I've seen some spray paints (forget the brand) but you buy it as a three pack, primer, colour and laquer.
Yep, my fairing is black and I want to make it flourescent orange.
You've given me a good start though, thanks.
Now what?
The last post was made 21 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 3.56 - MySQL Queries: 13 - Page Size: 64.64 Kb
