2001 Honda CBR 900 RR ( 929 ) Will not crank/turn over
MudSweatnGear...
PostPosted: 15:09 - 14 Apr 2015    Post subject: 2001 Honda CBR 900 RR ( 929 ) Will not crank/turn over Reply with quote
Hi everyone!
Got a quick one for anybody knowledgeable with these models; Essentially I had been given this bike to repair its fuel pump; everything else worked but it wasnt getting fuel past the pump.
So new pump on, ignition on, primed weheyyyy fixed....
hits the starter button, and click.. click click click.. ( So i went for the jump pack )
Jump pack on, primes and cycles through like it should but this time I only get a single click.
I have noticed however that when I am hitting the button im losing quite a significant amount of voltage, I go from a steady 13.00 to around 4-6 when i hit the button.
I have checked the starter relay and all seemed to be fine apart from the ground test, I should be getting a little resistance from the diode but i gets sod all. Yet if i pull the bike off its stand, pull the clutch in and whack in neutral and i get continuity like i should.
Now im personally thinking the relay is shagged, As testing the grounding side of it doesnt show what the book says. I also tested the diode and that is working like it should.
What do you think everyone? Pisses me off when this happens. Fix one thing and another problem comes up.... I wouldnt mind but the bike has only done 3k miles.
Thanks in advance!
www.adrenaline-motorcycles.com.
kramdra
PostPosted: 20:20 - 14 Apr 2015    Post subject: Reply with quote
Correct, you have a short somewhere. To drop voltage, either its a flat battery or something is burning current, lot of it, and that will get hot.
If the relay and wiring has no noticable heat, Id suggest the starter motor is the only item capable of sustaining a decent current for more than a few seconds without melting - its got enough metal that it wont get noticably hot, but dont hold the button for more than a second if its not turning.
You could try tapping the starter casing, though Id take it off to inspect. Also worth checking the engine turns by rolling it forwards in gear.
Nemo
PostPosted: 20:56 - 14 Apr 2015    Post subject: Reply with quote
Usually indicates a knackered battery.
Put a screwdriver across the two terminals on the starter relay, if it turns over and starts, your relay is knackered.
Very rare for the starter motor to die, but not impossible, leave that test until last by taking it out and putting a battery on it, if it spins, all good; but again, unlikely.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
bikenut
PostPosted: 10:07 - 15 Apr 2015    Post subject: fuel Reply with quote
yes, does the engine turn over freely........fuel pump problem....cylinders full of fuel perhaps...rule that out first.......
nuts about bikes
MudSweatnGear...
PostPosted: 12:39 - 15 Apr 2015    Post subject: Reply with quote
Kramdra, I have tried all of what you have suggested, to no avail seems the negative lead on the battery is getting super hot!
Nemo, Thats what i initially thought, thats why i grabbed the jumper pack. tried to jump the terminals like suggested and only get a single click like with the battery pack.
Bikenut, Its funny you should say that, i was looking at the airbox earlier and noticed a line of fuel running down the block, Im gonna take off the airbox and pull the plugs, try with zero compr.. and go from there.
Again, thanks to all who have replied!
kramdra
PostPosted: 13:43 - 15 Apr 2015    Post subject: Reply with quote
So the bike does roll in gear, the cylinders are not full of fuel?
Then I suggest the starter is mechanically stalled or has an internal short.
MudSweatnGear...
PostPosted: 13:58 - 15 Apr 2015    Post subject: Reply with quote
Sorry, i forgot to mention it just locks up the wheel when bumping. Also Im pretty sure i found what is wrong, took the airbox cover off and took a look down the stacks and cylinders 1&2 are chock full of fuel!!! I can only but assume where its been sat and tried to be started its filled itself up?
Oh well time to try and not blow myself up Laughing
Will let you know what happens.
P.
PostPosted: 14:04 - 15 Apr 2015    Post subject: Reply with quote
Vacuum tap failure or are they pumps on these?
MudSweatnGear...
PostPosted: 14:24 - 15 Apr 2015    Post subject: Reply with quote
Pumps on these, just to make life a little more complicated!
Nemo
PostPosted: 14:38 - 15 Apr 2015    Post subject: Reply with quote
Hydraulic lock, more common on carbed machines, just where it's been turning over and not firing, thus filling with fuel, been known to bend con-rods.
Take the plugs out, turn engine over and stand back.
If it's been sat a while put a couple of drops of oil in each cylinder.
MudSweatnGear...
PostPosted: 21:56 - 15 Apr 2015    Post subject: Reply with quote
Nemo, Most definitely; i drained around 500ml just out of the throttle bodies, god only knows how much was in the cylinders. Will be putting her back together again tomorrow so fingers crossed no big damage has happened!
kramdra
PostPosted: 23:53 - 15 Apr 2015    Post subject: Reply with quote
Any idea how long she has been full of fuel? oil change is probably needed.
Do some carbs not have overflow pipes, or perhaps it the angle they sit at, forcing it into cylinders? On my 250RR I've extended the overflow pipes by 6 inches so its much easier to check and to keep hot fuel away from engine.
Nemo
PostPosted: 07:25 - 16 Apr 2015    Post subject: Reply with quote
The 929 is fuel injected.
kramdra
PostPosted: 12:14 - 16 Apr 2015    Post subject: Reply with quote
Ah, missed that bit Embarassed
Thats a hell of a lot of fuel, must be holding the button for a long time? Shocked
P.
PostPosted: 12:41 - 16 Apr 2015    Post subject: Reply with quote
I don't see how holding the button would do it. Fuel should get cycled out through the exhaust no?
Nemo
PostPosted: 13:04 - 16 Apr 2015    Post subject: Reply with quote
Could have a leaky injector?
MudSweatnGear...
PostPosted: 13:19 - 16 Apr 2015    Post subject: Reply with quote
So ive started the draining process today, took sump plug out and have drained almost 10litres of fuel alone before any oil had appeared in the mix, needless to say it stunk and now i stink of it aswell...
Popped off the spark plugs and turned over the engine to then be met with a cloud of fuel, so now that is sorted im gonna be refreshing the oil and hopefully fingers crossed she will run!
good news is nothing was wrong with the starter motor or its circuit so atleast further inspection payed off.
thanks for all your help everyone! Cool
P.
PostPosted: 13:58 - 16 Apr 2015    Post subject: Reply with quote
I'd probably be checking the injectors for any form of damage or wear... seems strange to have fuel in there when engine is off...
bikenut
PostPosted: 10:12 - 17 Apr 2015    Post subject: fuel Reply with quote
good job you checked eh!!!!!
I bet the engine is well clean inside now!!
new oil and filter after allowing the engine insides to "breath" and get rid of all the fumes.....leave alone for a day will holes open........
insert oil and filter and with plugs out, turn engine over by hand to prime the oil system.....yes it may take some time and effort but this is a ducati ( wtf did that come from its a Honda! ) and is worth mega bucks ( not worth quite so much then, but still worth a lot to you ) ??!!
when the oil light goes out it will be safe to crank with plugs out and ign killed.........
so, flooding with fule injection.....does the fule pump run when ign is turned on a stop after a few seconds, when the inj system is primed and up to pressure??
pressure sensor somewhere and probably a "turn off ijn system " sensor when eng stopped ( and ign still on ) as if in a crash?
nuts about bikes
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 105.2 Kb
