| merky69 |
 merky69 Borekit Bruiser
| bikenut |
 bikenut World Chat Champion
| merky69 |
| bikenut |
| bikenut |
 Posted: 15:06 - 17 Apr 2015 Post subject: k start |
diagrams just come over......14 is the return spring, oh great the diagram has now gone.......there is an idler ( 1 ) in mesh with the clutch, a gear wheel ( 15 ) in front of the return spring and a sliding sprung loaded rachet ( 18 ) ...which connects with its gear,,,, you see the siding rachet gear.........mechanism
on the k/start return due to the return spring, the sliding ratchet is made to disengage, via the arm on it and a ramp .........the ramp will be on the casing.........
so the first movement of kicking of the k/statrt on starting , the sliding rachet is allowed to turn and mesh with its partner, by going down the ramp......and engaging with the rachet mech........the rachet mech is like a free wheel for when the motor actually starts, and will make a noise if the k/start is not at rest....as the rachet "rachets"......
the kick start shaft has a slot in the inner end?? which engages with the centre of the return spring??
and a post or peg or similar for the return spring eye to locate??
you will have to wind up the spring maybe half a turn or may be one turn to pre load it, so that it makes the k/start shaft want to return to the Neutral or idle position ( k/start well and truelly OFF ).......
remember when assembled properly, pushing the k/start to start the engine will wind this spring up more, so find out by how much it needs preloading........else it will break.......
are there any aligning dots or marks on the k/shaft and sliding rachet ?? ____________________ nuts about bikes |
| merky69 |
| bikenut |
The last post was made 10 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
