After a GP100 engine rebuild...
What shall I do?
Break it in gently as per manufacturers guidelines
75%
 75%  [ 3 ]
Treat it hard so the rings bed in quicker and gives more power output
25%
 25%  [ 1 ]
Total Votes : 4
Milo
PostPosted: 14:09 - 30 Jan 2005    Post subject: After a GP100 engine rebuild... Reply with quote
I remember reading a theory someone posted on here ages and ages ago.
I can't remember the details but it was something like if you follow the manufacturers guidelines you won't have as much power output once it's worn in.
If you give it a bit of a reasonable thrashing and still vary the revs and all that then it'll boost the power output as the piston rings will be morn worn with the barrel.
Anyone got a link to this original article or experience with this?
Shaft drives rule. Razz
TheShaggyDA
Repost Police
PostPosted: 14:19 - 30 Jan 2005    Post subject: Reply with quote
The link is on my other PC - I'll dig it out if no-one else posts it. If I recall, it was more relevant to give the engine a thrashing if it was a modern engine - not a 25+ year old design.
mchaggis
PostPosted: 14:59 - 30 Jan 2005    Post subject: Reply with quote
I think the basic thing was to just make sure that it's warmed up properly before you do anything. Then do anything, just not too much of the same thing for too long. (A proper warm up and then variation in engine rpm and load are the main things I think.)
An accelerated slow and steady approach worked fine for me. I just got the rpm higher and higher over the miles, working into higher and higher gears over time. I was sometimes redlining fifth by 500 klicks and the engine's running sweet as a nut (with much thrashing) 2000 later.
I must not be a troll...
Mmmm, Guinness
Milo
PostPosted: 19:57 - 31 Jan 2005    Post subject: Reply with quote
Taking it easy it is.
I'm staying slower than 50 and not letting it rev over 5k ish at the mo.
Every 50 miles shall I add 1k onto the revs?
TheShaggyDA
Repost Police
PostPosted: 20:18 - 31 Jan 2005    Post subject: Reply with quote
Here be the link.
https://www.mototuneusa.com/break_in_secrets.htm
The last post was made 21 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.76 - MySQL Queries: 15 - Page Size: 45.93 Kb
