| Medicinal_Motocross |
 Medicinal_Motocross Nova Slayer
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 15:29 - 22 Apr 2015 Post subject: |
It would be a good idea to get hold of a copy of the official owner's manual, to see if there are any specific recommendations for the running-in period. If not, I wouldn't worry about it following a re-build.
If you do feel it would be a good idea to increase the oil / fuel ratio and there's no convenient way to do this automatically, you could add a small amount of 2T oil directly to the fuel, to supplement the oil delivery system.
A small investment in a cheap multimeter will help determine the state of the battery and the charging system - much cheaper than replacing the horn!
If the horn does prove to be defective, there are many cheaper alternatives available on eBay. ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| chris-red |
| Old Git Racing |
 Old Git Racing World Chat Champion
| stevo as b4 |
 Posted: 03:05 - 23 Apr 2015 Post subject: . |
I dont really have anything to measure amounts of 2t putting into the fuel tank specifically would go with less precise cap fulls, would i get away with putting 100ml into the tank with full tank of fuel (9litres) aswell as its autolube without affecting anything?..
Im just starting off on tinkering with bikes so im not all that sure but remember reading someone running it with more 2t oil than usual for the run in period.
Im aware of the varied throttle but low load on the engine will keep it out of the powerband for the duration but i will need to check the valve and actuator are set up correct when should i do this it opens around 6-7k?
Its also a KMX 125. It has a standard expansion chamber so i believe has stamped KXM 154 or something similar but believe it be and a old style DEP exhaust at the back. Being a while ago i think had expansion & tail can both being dep and was using standard 102.5 main jet never had any problems? .. I really dont have time to order and wait for bigger jets would i be fine using the standard 102.5 for the time being? What are signs that its not running as it should mixture wise other than spark plug anything?
The horn moves when pressed pushes itself out but no sound i stupidly sprayed ACF50 on it which is probably why its had it now so gona have to somehow buy a cheap horn and use its bracket to mount to my headlight headlight/meter bracket |
| MarJay |
 MarJay But it's British!
 - Super Spammer
| Ryder666 |
 Ryder666 Two Stroke Sniffer
The last post was made 11 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
