after cleaning chain it makes spacedust/pop rocks noise
daifuco
PostPosted: 20:22 - 28 Apr 2015    Post subject: after cleaning chain it makes spacedust/pop rocks noise Reply with quote
After 6 weeks I cleaned the chain and the other bits for the first time. It is a cbf125 with 0 rings, whatever that means
The chain had a lot of black goo, I emptied a whole can of WD-40 chain cleaner (i know, paraffin works as well, but I did not like the idea of riding with 4 litres of highly flamable stuff on my back)
The chain cleaner is supposed to be compatible with O rings chains. I did not brushed on the sides as the manual said. I brushed the top and botton, then i used a dry cloth on the chain. At that point you could actually see the chain colour.
After that I aplied a lot of gear oil with a brush up to the point that you could see a film of oil all over the chain.
Now it makes a funny ramdon noise, like space dust or pop rocks or that sparkling sugar that was sold in sachets long ago.
Any idea what could it be? I am worried that I went too far with the chain cleaner, it was amazing to see how it removed the guck. Maybe I went too far with it?
Andy_Pagin
PostPosted: 20:33 - 28 Apr 2015    Post subject: Reply with quote
How old is the bike and chain, how many miles on it?
recman
PostPosted: 20:37 - 28 Apr 2015    Post subject: Reply with quote
Did you clean the front and rear sprockets?
PostPosted: 21:07 - 28 Apr 2015    Post subject: Reply with quote
Fancy YouTubing a video?
daifuco
PostPosted: 21:30 - 28 Apr 2015    Post subject: Reply with quote
The bike rides well, very well actually. I think I could feel it smoother that I remember. If tomorrow it keeps making that noise I will upload a video.
It was amazing the amount of dark goo around the front sprocket. I think I might be the first one who cleaned it. It has 4800 miles.
Another question, Is it a good idea to spray a bit of WD 40 over the engine and exhaust? The engine looks shinier, and the exhaust is beggining to develop some rustiness (tipical cbf 125)
It is the first time I clean the CBF125! it actually looks nice!
grr666
PostPosted: 21:39 - 28 Apr 2015    Post subject: Reply with quote
It will burn off quickly, and stink doing so. I wouldn't bother.
ACF50 is what everybody here swears
by for keeping bikes rust free.
https://www.acf-50.co.uk/motorcycle.htm
Andy_Pagin
PostPosted: 10:27 - 29 Apr 2015    Post subject: Reply with quote
funny ramdon noise, like space dust or pop rocks or...
Removing a large amount of muck will result in the surfaces of the moving parts meeting in a slightly different way, plus there will still be a bit of grit and dust there, so it's bound to sound different. I suspect that after a few more miles and a few more cleans it'll quieten down.
Also don't forget to check and adjust the chain slack regularly. My YBR125 needed a little bit of adjustment every 800 miles.
trevor saxe-coburg-gotha
PostPosted: 10:34 - 29 Apr 2015    Post subject: Reply with quote
When you first oil a very clean chain you *will* hear a funny crackling and popping noise - however, it's pretty damn quiet and you have to listen carefully as you turn the rear wheel. Not sure if this is the sound you're talking about, but I hear it regularly. As in, every time I lube the chain. It goes away if you continue rotating the back wheel - it just seems to make the poppy sounds for, say, the first ten or twenty turns. After that it seems to not do it. I don't quite know what it is, but I've always assumed it's just the sound made by the freshly lubricated globs of oil getting compressed between the sprocket and the chain's rollers. Regardless, I do honestly believe it's the sound of a happy chain and grateful sprockets - and roughly translates as "oh yeah uh huh mm mmm that's right that's the stuff right there yep - that I LIKE!!!"
Matt B
PostPosted: 10:41 - 29 Apr 2015    Post subject: Reply with quote
That's what it is. Non-fling chain lube is especially sticky and makes those noises as it gets squashed and pulled apart between the chain and sprockets.
kris84
PostPosted: 12:12 - 30 Apr 2015    Post subject: Reply with quote
Check your wheel alignment, could be the sound of the chain trying to come off the sprocket at a slightly odd angle.
CBT April 14, Theory passed May 15, MOD1 passed May 16, MOD2 passed June 16
Custom GS550 chop - Ducati Hyperstrada
The last post was made 11 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 66.42 Kb
