Loss of rev , temp gauge and electrics on Vfr Nc30
Juicyjayjay
PostPosted: 08:14 - 08 May 2015    Post subject: Loss of rev , temp gauge and electrics on Vfr Nc30 Reply with quote
Hi all
Im new to this forum , all the help i can get would be greatly appreciated.
Took my vfr out for a spin , this only started yesterday , for the first few miles the bike was running fine and all of a sudden temp gauge and rev gauge are non operational ,the lights on the bike and around ignition are non functional , the bike has lost alot off power almost seems as if it was running out of gas like the bike was stammering and shaking then all of a sudden everything is working again.
Please any help would be greatly appreciated.
RhynoCZ
PostPosted: 08:36 - 08 May 2015    Post subject: Reply with quote
Check the fuse box, then the wiring on the back side of the clocks and around the main fuse. Thumbs Up
Juicyjayjay
PostPosted: 08:42 - 08 May 2015    Post subject: Reply with quote
Thanks Rhyno , i do ride alot of bumpy roads , ill check it out
RhynoCZ
PostPosted: 08:59 - 08 May 2015    Post subject: Reply with quote
Also, check the battery leads and terminals, I've seen many bikes with damaged terminals and when on a bumpy road it was disconnecting the battery from the the circuit. Corrosion on the terminals also can lead to such a behaviour, clean the terminals while you're in there.
Juicyjayjay
PostPosted: 09:25 - 08 May 2015    Post subject: Reply with quote
The battery i currently have on the bike is a sealed battery which started leaking abit of battery acid but stopped , waiting for stock from the battery centre , its been running ok for awhile now even with the damaged battery , gotta run start it at times but just yesterday it has started with the problems , iv also checked wiring where the battery acid spilt
Juicyjayjay
PostPosted: 10:18 - 08 May 2015    Post subject: Reply with quote
Vincent wrote:
Make sure the CDI is fastened down correctly. If they can move about, it can damage the wires where they enter the box. Sounds like you may have a loose connection somewhere.
where would i be able to locate the cdi unit, i don't have a clear wiring diagram on hand. So all my power loss could just be from some faulty wiring? Shocked
RhynoCZ
PostPosted: 11:11 - 08 May 2015    Post subject: Reply with quote
Well now, leaking battery, dropping charge, well, get a new battery and if you still gonna have problems, it's all the above said. Thumbs Up
Juicyjayjay
PostPosted: 08:17 - 11 May 2015    Post subject: Reply with quote
Update on the issue i finally received my new battery popped it in and same problem , i then proceeded to do full wiring check to find 2 bubbled up/half melted fuses in the fuse box aswell as a blackening around one of the pins on the regulator.
I wonder if there is not another issue causing all of this.
Please help Shocked
mentalboy
PostPosted: 08:48 - 11 May 2015    Post subject: Reply with quote
Considering that you have no manual (probably wouldn't hurt to buy one if you like to try to fix stuff yourself rather than have a garage do it) photo's indicating the positions of the dead fuses may help us identify which circuits have issues
Make mine a Corona.
Juicyjayjay
PostPosted: 09:50 - 11 May 2015    Post subject: Reply with quote
The fuses that blew were for the ignition lights the neutral and indicator , funny enough the headlights didnt blow at all , the other was for the temp gauge which is now working , i will put up a picture when i get back , also wondering what could burn/blacken the one pin on the regulator?
The last post was made 11 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 71.28 Kb
