| salem1987 |
 salem1987 Scooby Slapper
 Posted: 19:48 - 07 May 2015 Post subject: Rd200 1982 build |
(Admin please move to show & tell if possible)
Purchased this yesterday to build up and use on the practical sports bike classic track day in july and just wondered if anyone could point me in the right direction for wiring up the points system as ive only really got experience with CDI stuff.
The bike is a 1982 RD125 with lots of custom bits as you can see, also a rd200 top end fitted.
The bike:
https://s10.postimg.org/4b7uvs71l/IMG_0270.jpg
The points wiring currently:
https://s10.postimg.org/vblnkcvc9/IMG_0271.jpg
Ive got the wiring diagram and i can see where the coils are going to be wired but i'm slightly confused with the thick green wire along with the thinner one.
| bypass2 |
 bypass2 Spanner Monkey
| salem1987 |
 Posted: 21:03 - 07 May 2015 Post subject: |
thanks any photos would be much appreciated.
The reg/rec and all original wiring is in a box right now, and with the mono shock being mounted up behind the tank im guessing its going to be a little different routing wise.
Im currently attempting to follow this diagram:
https://i1233.photobucket.com/albums/ff399/calle_o/AS3RD1251973wiringdiagram.jpg
From what i've figured out:
Orange and grey wires trigger the coils.
White is from the alternator
Unsure of the thin dark green wire just above the thick green one and the black wire below the white one on my photo above. |
| salem1987 |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| bikenut |
 bikenut World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 14:20 - 08 May 2015 Post subject: |
Aye...set the timing by measuring degrees before TDC. You need a dial gauge and one of those circular gauges that you attatch to the end of the crank...IYKWIM. There was someone selling some decent gauges with an adapter for the plug hole on one of the stroker forums a while back, I'll try and find the link......
I'm not sure how, what what looks like an automatic advance retard unit type thingy, will effect things
That is a standard set-up, ja Have you thought about fitting electronic ignition? Is that allowed?
Yambits are doing the gauges:-
https://yambits.co.uk/dial-gauge-ignition-timing-tool-p-12695.html ____________________ Space Is Deep |
| bikenut |
| MCN. |
 MCN. Banned
| salem1987 |
 Posted: 17:55 - 08 May 2015 Post subject: |
thanks a lot of all the advice so far.
Not going to the anglesey one no but cadwell yes, are you bikenut?
Got it running today just on a total loss system for now. Might keep it that way but not sure how fast it will eat a battery during track time?
The points gaps were both at around 1mm....
Set it right back down to 0.30mm and it seems to run well.
Next week im going to work on getting the timing spot on, so will follow your advice regarding it.
That's interesting regarding the fact its just an RD200 engine, i was told by the seller it had been swapped and he seemed to know his stuff about RD's but maybe he's got it wrong.
The CDI ignition is allowed for what i'm doing and sounds very tempting and i'm going to look into that.
As you have probably guessed the bike is an unfinished project as i bought it, so getting it running and hearing the engine is solid has took a lot of weight off my shoulders!!
Will post any photos of progress as i do it. Thinking TZ250 fairings and some proper rearsets so far cosmetics wise. |
| bypass2 |
| MCN. |
 MCN. Banned
| salem1987 |
| bypass2 |
| bypass2 |
| Vincent |
 Vincent Banned
 Posted: 13:41 - 09 May 2015 Post subject: |
The pipes don't look too good Interesting frame though.....TZ125? Maybe the forks and yokes are TZ  ____________________ Space Is Deep |
| MCN. |
 MCN. Banned
| salem1987 |
 Posted: 19:45 - 09 May 2015 Post subject: |
Gearbox is fine just the chain was old so its removed at the moment in preparation for a new one.
Pipes are not too good at all, going to be replaced eventually as they are very dented. Anyone know what pipes they actually are/were? lol
The frame is from a RD125 1982 as i have the logbook for it. The swinging arm and shock etc have been fabricated.
Front wheel is also unknown, 17inch and wider than the rear so definetly not RD i believe. If the forks turn out to be RD ones i will be replacing the wheel for the correct type.
The forks do look very Yamaha if you look at the bleed screw position compared to other RD's especially.
The mystery forks search continues!
| MCN. |
 MCN. Banned
| bypass2 |
| salem1987 |
 Posted: 15:50 - 10 May 2015 Post subject: |
| salem1987 |
| salem1987 |
 Posted: 21:34 - 12 May 2015 Post subject: |
UPDATE:
Have now ditched the whole kawasaki/chinese front end and fitted a spare CB250RS set of very rough looking (for now) forks, brake caliper and wheel.
If i can get the brake anything like the one on my CB it should be ample for the little RD.
https://s12.postimg.org/rfq709i4p/IMG_0288.jpg |
| Vincent |
 Vincent Banned
| MCN. |
 MCN. Banned
The last post was made 11 years, 144 days ago. Instead of replying here, would creating a new thread be more useful? |
