Question regarding A2 licence and bikes
james_c_123
PostPosted: 00:10 - 10 May 2015    Post subject: Question regarding A2 licence and bikes Reply with quote
So I'm gonna be doing my A2 licence shortly and I was wondering. Do the DVLA/Insurers/Whom it may concern rate bikes that are A2 compliant from the original spec or if you take a dyno of the bike now as standard would they then allow you to restrict it? (hope this makes sense) thanks in advance!
James
Who ate the pie?
I ate the pie.
Case closed.
PostPosted: 00:33 - 10 May 2015    Post subject: Reply with quote
You can restrict it, but only if the bike started life with a manufacturers claimed power below a certain level
K
PostPosted: 00:34 - 10 May 2015    Post subject: Reply with quote
As far as I am aware they use the factory specs to define the power output. You would need to restrict it, and have proof of restriction before you take the tests and the bike must comply with the A2 rules.
josh95
PostPosted: 00:48 - 10 May 2015    Post subject: Reply with quote
Yeah they just have a database of A2 compliant bikes that they check,
you can restrict anything within 50% of its original power
PostPosted: 08:54 - 10 May 2015    Post subject: Reply with quote
Who is/are "they", and on what information are you making this statement?
The correct answer is that there's no correct answer and every tool of the state or the insurance cartel will apply their own interpretation when stitching you up.
Plain common sense would suggest that it has to be the manufacturer's claimed figure, not a tested figure. If the latter was acceptable, you could trivially restrict an H2 to 70kW with a throttle stop (just clamp something on the throttle cable), dyno, then move the clamp go down to 35kW, dyno, and that's you 'legal'.
DVSA have their own list of A2 test bikes:
https://www.dft.gov.uk/motorcycle-test-vehicle-list/
That's not an exhaustive list of bikes that you can ride on an A2 though as it only covers 395cc+, and it's not even strictly accurate either. Some years of some models don't quite meet their criteria.
You can try looking here:
https://a2bikes.co.uk/
But it's suggestive, not definitive, and plain wrong in some places. Most notably that damn 1996-2000 GSX-R600. The 69kW Wikipedia figure that keeps getting quoted for it is a tested rear wheel figure, not the 'net engine power' that matters. There's a spacker on Wikipedia who keeps deliberately hiding that detail, and a2bikes have rejected my comment about it as well for reasons best known to themselves.
tl;dr version is get a Bandit 600/650 or SV650 or something else that's clearly under 70kW if you want to be absolutely sure. Once you start trying to get clever with SRADs, Hornets and Fazers, you're at a very, very small risk of being caught out by a theoretically clued up copper or insurer.
Sorry that's not the clear answer you wanted.
Val
PostPosted: 14:08 - 10 May 2015    Post subject: Re: Question regarding A2 licence and bikes Reply with quote
James
Here are the LEGAL rules:
Category A2
This is a motorcycle without a side car that:
is at least 395cc
has a power output between 20 kW and 35 kW (26bhp and 46.6 bhp)
There's no upper engine size limit, but:
the power to weight ratio must not exceed 0.2kW/kg means cannot restrict some powerful sport bike
it must not be derived from a motorcycle of more than double its power THIS RULE MEANS YOU CANNOT GET bike with more than 93.2bhp and restrict it
DVSA will accept evidence from manufacturers or official importers that a specific model of motorcycle meets these rules. DVSA will publish this information where it applies to a number of machines of a specific type.
And list of A2 bikes that MAY BE restricted (see my note below):
There are 2 routes to ride A2 bike:
1. Get one the has less power as manufactured and comply with A2
2. Get bike that is more powerful BUT also comply with A2 restriction pre-requisites above
Note the DVLA A2 list is for GUIDANCE only! Means if they got it wrong legally it is up that your bike comply!!! For instance, the Triumph Street Triple is listed as A2-legal once restricted to 47kW, but the fact that bike makes 105bhp as standard should, theoretically, make it ineligible. If you want to be 100% legal better ignore the Government list and find machines that have the specs to fit the A2 class.
Read more: https://www.visordown.com/learners/the-5-fastest-a2-motorcycles/23194.html#ixzz3Zjz00ROt
To answer your question Do the DVLA/Insurers/Whom it may concern rate bikes that are A2 compliant?:
DVLA has nothing to do with restrictions and are not concerned as far you riding one. Insurers and cops will be concerned and your proof for restriction will be:
1. Get one the has less power as manufactured and comply with A2 - the manufacturer specifications document. Say Suzuki DR-Z400 has 39bhp
2. Get bike that is more powerful BUT also comply with A2 restriction pre-requisites above - the document for the restriction that has been provided by DVSA certified garage.
james_c_123
PostPosted: 17:11 - 10 May 2015    Post subject: Reply with quote
So there is absolutely no way I could buy a bike that came with more hp but has lost it and now fits the requirements cos its got old?
Who ate the pie?
I ate the pie.
Case closed.
PostPosted: 17:18 - 10 May 2015    Post subject: Reply with quote
No. In a word.
james_c_123
PostPosted: 17:32 - 10 May 2015    Post subject: Reply with quote
Thanks Pinky! So whats the deal with that 96-00 GSXR? MCN also have it as 92BHP but everyone else says no?
Who ate the pie?
I ate the pie.
Case closed.
PostPosted: 18:20 - 10 May 2015    Post subject: Reply with quote
MCN. Rolling Eyes
Here they make a point of saying "it does have an electric start" about a bike that's famously kick-start only.
https://www.motorcyclenews.com/bike-reviews/kawasaki/klr250/1984/
Did they ride it? Have they even seen one? I doubt it.
Right, that 92hp / 69kW figure comes from here:
https://www.mcnews.com/mcn/articles/2010JanIndex.pdf
It's clearly labelled 'rear wheel HP'.
Wishing won't make it otherwise, and neither will citing Wikipedia, because that's the source for their article on it as well.
If you want A2 and plastic, it'll need to be a fully faired SV650, GSF650A, GS500F, ER6F, 400 IL4 or similar. Not the Gixxer. Forget it.
james_c_123
PostPosted: 20:44 - 10 May 2015    Post subject: Reply with quote
So whats peoples thought on the Ninja 400 from the 90's?
Who ate the pie?
I ate the pie.
Case closed.
wr6133
PostPosted: 20:53 - 10 May 2015    Post subject: Reply with quote
Thumbs Up IL4 400's are great fun, just take time to find a good example
The last post was made 11 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 78.1 Kb
