bike dies when hard braking?
Kwakki Si
PostPosted: 18:23 - 10 May 2015    Post subject: bike dies when hard braking? Reply with quote
Hi peeps,
if i have to slam on the brakes and come to a stop sharpish the bike cuts out, standard braking is fine, any ideas apart from braking earlier :p
MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike!
Andy_Pagin
PostPosted: 18:30 - 10 May 2015    Post subject: Reply with quote
Pull the clutch in Wink
Kwakki Si
PostPosted: 18:34 - 10 May 2015    Post subject: Reply with quote
Ha lol, maybe in all the hast im fluffing up my clutching?!
I know on some cars they have a spring so if you suddenly come off the gas the spring slowly closes as to not suddenly starve the engine resulting in it cutting out, just thinking maybe some bikes have the same and a springs knackered.
Snod Blatter
PostPosted: 19:11 - 10 May 2015    Post subject: Reply with quote
I have had CV carbs cause this if the choke is stuck on a bit, at a guess the slides come down a bit and the mixture richens too much at that moment.
How's the fuelling generally?
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Kwakki Si
PostPosted: 19:27 - 10 May 2015    Post subject: Reply with quote
Seems good as far as i know, it goes like the clappers, i did change the spark plugs recently and they were black? but they have been in there for about 3 years!
The choke is shit, when you start the bike the choke works for a bit then its like it completely shuts off so i just use the throttle to keep the bike idling until its warm enough to ride.
Snod Blatter
PostPosted: 20:13 - 10 May 2015    Post subject: Reply with quote
If the plugs are black, the choke doesn't seem to work properly and it cuts out when you come to a stop I would be checking out the choke mechanism and carbs in general. Has it been messed with? Or stood a long time?
Kwakki Si
PostPosted: 07:14 - 11 May 2015    Post subject: Reply with quote
its been used fairly regulary over the past 3 years, i think the bloke that had it before rarely used it, the choke has always been hit or miss on it but its just something i got use to, this cutting out problem seems to be a new thing, im pretty sure the carbs could do with a bit of work?
Robby
Dirty Old Man
PostPosted: 07:39 - 11 May 2015    Post subject: Reply with quote
If the plugs had been in there 3 years, have you been remiss with other servicing? A clogged air filter will cause a rich mixture and other cocking around.
Don't go chasing down big problems - like anything involving removing the carbs - until you have eliminated the small ones. Service it, charge the battery, see if it starts to behave.
Kwakki Si
PostPosted: 17:05 - 11 May 2015    Post subject: Reply with quote
I stay on top of the oil and that gets changed every 6months and then oil filter every other oil change, must admit im a bit slack when it comes the the other bits, but i gave it a full service on saturday, i did oil, oil filter, fuel filter, air filter and plugs, shes running well nice after!
Do you reckon it could be the centre stand switch triggering as im slamming on the brakes? just a thought i had earlier.
The last post was made 11 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 61.27 Kb
