78 Kawasaki KE100 Spark problem
jfeyen
PostPosted: 18:15 - 10 May 2015    Post subject: 78 Kawasaki KE100 Spark problem Reply with quote
Here is what I have going on. 78 KE100. When I bought it the guy told me it has no spark. He replaced the coil, but still didn't get any spark. I have replaced the points and the condenser in it. It I take a test light to the harness where the coil connects I can light up the test light nice and bright. As soon as I connect the coil to the harness I get nothing in the test light. I tested the coil. This is what I am getting.
The harness lead to the coil mount 00.8 Ohms
The harness lead to the plug wire 5.62K Ohms
The book says around 5K is good. I dont know what to do next with it. I have tried a new coil, and with a good coil it is doing the same thing.
Taught2BCauti...
PostPosted: 09:41 - 11 May 2015    Post subject: Reply with quote
On the LT side of the coil, check that you have a good +12v on one side, and that the other side goes to the points with no breaks or shorts.
Is the coil clearly marked + and - ? If so, make sure you have it wired the right way round, and try disconnecting the - side (that goes to the points) and replace it with a spare piece of wire connected to earth. You should get a spark when you disconnect it from earth.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
bypass2
PostPosted: 21:20 - 11 May 2015    Post subject: Reply with quote
what about worn/broken woodruff key.
The last post was made 11 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 49.05 Kb
