Datatool 3 weirdness, arming itself when on.
Marmaduke
PostPosted: 20:01 - 13 May 2015    Post subject: Datatool 3 weirdness, arming itself when on. Reply with quote
Bike was under a cover for winter after blowing over and waiting for parts.
When I disarm it, it will beep like normal, I'll turn the ignition on and it won't start, it'll flag up an EFI error eventually, and then it will arm itself again! And then I have to disarm it again and all is good after cycling the ignition.
I'm thinking the ignition pick up for the alarm or whatever they done when installing it has gone bad but am wondering if there's something I'm missing.
Really don't wanna rip it Crying or Very sad
Current: '03 Tuono RSV1000, '05 Van Van, '91 Zephyr 550
Previous: Multistrada 620,Bandit 600,Kawsaki ER-5, BMW K-75
CaNsA
PostPosted: 20:02 - 13 May 2015    Post subject: Re: Datatool 3 weirdness, arming itself when on. Reply with quote
Do it
Be happy.
Marmaduke
PostPosted: 20:12 - 13 May 2015    Post subject: Reply with quote
Noooo! I like how it beeps and stuff...
And I'll make it worse trying to put the loom back together, probably won't work at all!
CaNsA
PostPosted: 20:13 - 13 May 2015    Post subject: Reply with quote
Rip it out.
misscrabstick
PostPosted: 20:18 - 13 May 2015    Post subject: Reply with quote
because...... datatool.
Fisty
PostPosted: 20:57 - 13 May 2015    Post subject: Reply with quote
Kill it.
Fatter and faster than Fret
PostPosted: 21:41 - 13 May 2015    Post subject: Reply with quote
Open case, bypass completely with two pieces of bent wire:
https://www.sonicsideshow.com/blog/-how-to-bypass-a-datatool-system-3-motorcycle-alarm
Protip: If you have the manual handy, you can remove the staples and use them to perform the bypass.
Then, leaving the wiring connected to your loom, remove the rest of the unit and perform maintenance:
https://youtu.be/_mXLdHVnDfk?t=29
Fairly seriously, these things appear to be so trivial to bypass in this way that they're Arec Bordwin worfress.
Having one fitted would (and did) actively put me off buying a bike.
Marmaduke
PostPosted: 08:25 - 14 May 2015    Post subject: Reply with quote
Alright I think I get it...I'll look into taking it out :p
It is over 10 years old now I suppose.
I'll post in here if I get stuck!
Thanks haha
tony_d123
PostPosted: 07:40 - 15 May 2015    Post subject: Reply with quote
Wish I had found this when mine was playing up and kept leaving me stranded. Removing it is the best thing you will do Thumbs Up
Blackpool, Lancashire
The last post was made 11 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 61 Kb
