Balancing Carbs
Andy_Pagin
PostPosted: 09:59 - 14 May 2015    Post subject: Balancing Carbs Reply with quote
It's about time I had my first ever attempt at balancing carbs.
I'm going to make a home made manometer for the job, and I've a few questions specific to balancing a 2003 Fazer.
What diameter tubing do I need?
How long should the tubes be, can you over do it?
Can I just prop the fuel tank up, or do I need to remove it and rig up a temporary fuel supply.
If I do need a temporary supply does it need to be gravity fed or will the vacuum/fuel pump be enough to siphon it up?
Any other Fazer specific issues I should be aware of?
Taught2BCauti...
PostPosted: 13:16 - 14 May 2015    Post subject: Reply with quote
I find 6mm internal diameter tubing is good, as long as it isn't so soft it can collapse or get easily kinked. Keep the length sensible to avoid a trip hazard, but if you want to make them longer, coil the surplus and tape or cable-tie it in place.
You might get away with propping the tank up on wooden strips, or get someone to hold it in place - I would prefer to do this before resorting to disconnecting the tank and using a temporary supply.
Also, I always try to keep the bike upright when adjusting carbs - either using the centre-stand or a paddock stand.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
andym
PostPosted: 16:36 - 14 May 2015    Post subject: Reply with quote
I found 5mm tubing was a better fit personally.
Anyway, the shorter the hose the thicker the liquid needs to be, also maybe a small set of mole grips to restrict the movement initially (depending on how far out they are)..... when I done the CBR I had to use engine oil, mole grips and crank the engine over with the kill switch set to off after a lecturer balanced them by ear Rolling Eyes
The last post was made 11 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 36.63 Kb
