| fatjames |
 fatjames World Chat Champion
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 20:50 - 12 May 2015 Post subject: |
No need to remove old paint if its sound, it just needs keying. Easiest way to do that is with a scotch brite pad rather than trying to sand them.
Sand any scuffs and scrapes out first (finishing with something like 600s wet and dry) then just scotch brite the whole wheel. Make sure you get in all the nooks and crannies, any areas you miss are where your paint will flake off at a later date  ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| fatjames |
 Posted: 12:37 - 14 May 2015 Post subject: |
Great thanks.
I tried to get the tyre off the front wheel last night. I stuck the tyre in my vice to break the seal. One side was fine, but the other side of the tyre is completely stuck! The whole wheel just moves, I can't even get a lever between the rim and the rubber.
It's like this - https://i.imgur.com/WuHZRIk.jpg
I've done this all the way round and it's the same. |
| fatjames |
| Just_James |
 Posted: 19:00 - 14 May 2015 Post subject: |
Are you trying to completely remove the tyre or just break the bead?
If you're removing it to replace it then be sure to fit the new one before you paint the wheels and just leave the bead broken until you're done.
If you're removing the tyre just to paint the wheels, don't! There's little chance you'll get the tyre refitted without taking off your new paint! Just break the bead and mask up the tyre with 2" masking tape, you'll be able to slip the tape right down behind the rim so you'll get no paint on the tyre and the only bit of the wheel you won't paint is the bit noone sees
https://i9.photobucket.com/albums/a75/RS1Rebuild/DPP_0684_zpse19b79b9.jpg ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| stevo as b4 |
| fatjames |
The last post was made 11 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
