Revs high after run on choke?
skatefreak
PostPosted: 09:21 - 14 May 2015    Post subject: Revs high after run on choke? Reply with quote
Rode into work this morning (Cbr 600 F3)
like a numpty I had left the choke on 3/4 of the way (16 miles, some fast/cruising/filtering).
Realising my mistake I pulled the choke lever and the rev's shot to 5,000 rpm!
I put the choke on just enough to bring the RPM back down but a few times on the way pulled it all the way back and it was still rev'ing high (kinda like cruise control!).
The bike was riding fine before although it has spent a good week or two sitting outside Neutral
Could a spirited ride on the choke cause any lasting damage?
any thoughts would be much appreciated.
Best regards
-Jvr
Gazza M
PostPosted: 13:11 - 14 May 2015    Post subject: Reply with quote
There's usually a fast idle thing (technical term) on the same cable as the choke - just pulls the throttle open a wee bit more to help warm the engine up. This could be stuck?
Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike
Taught2BCauti...
PostPosted: 13:20 - 14 May 2015    Post subject: Reply with quote
I think lasting damage is unlikely, but something might have got stuck due to it being in a certain position when it got hot and expanded.
Check everything is working smoothly and lubed when cold, and you should be fine.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
CaNsA
PostPosted: 13:24 - 14 May 2015    Post subject: Re: Revs high after run on choke? Reply with quote
Best regards
-Jvr
Get on a private bit of airport runway (the motorway) and give it a good couple of minutes of top gear full pinnings head on tank screaming down the road.
skatefreak
PostPosted: 09:09 - 15 May 2015    Post subject: Reply with quote
Cheers for the input fellas.
I think something may have got stuck but a manic wiggle session seemed to sort the problem out...
It does seem to have a tight spot so will investigate for any fouling down there.
Best regards
-Jvr
Jaco
PostPosted: 13:47 - 15 May 2015    Post subject: Re: Revs high after run on choke? Reply with quote
Best regards
-Jvr
What does this actually do? Not disputing it, just wondering what it would do to fix it.
The last post was made 11 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 50.01 Kb
