stanchions
dsharman1
PostPosted: 20:32 - 14 May 2015    Post subject: stanchions Reply with quote
i am in need of replacing my fork stanchions because they are pitted and have started leaking oil slightly but the ones for my bike a re hard to get so could i just get some from another bike with 37mm stanchions?
Aprillia rs 50 2000
derbi city cross 125 2007 (RIP 08/2015)
Honda CG 125 2001
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Ed Case
PostPosted: 22:32 - 14 May 2015    Post subject: Reply with quote
No, if the stanchions are in a poor state clean then up a little with some relatively smooth 'Wet & Dry' paper to shift any rust, put some new seals in, refill with fresh oil, and then fit some rubber gaiters and the MOT man won't have a clue and neither will anyone else. The cheapest way out unless you come across another pair of 'legs' in good order and cheap.
Commuter_Tim
PostPosted: 23:31 - 14 May 2015    Post subject: Reply with quote
Ed is right, but post photos of the stanchions here, and we can give you an idea of just how bad.
If you do rub the stanchions down, you're going to want to get some grit in the range of maybe 1000-3000.
use the coarsest first then work up to finer, change the sheets often as it builds up rust particles which make the paper coarser.
I ride a Bandit 600... badly.
Raffles
PostPosted: 23:49 - 14 May 2015    Post subject: Reply with quote
A video complete with voice over would give us a better understanding.
Casper
PostPosted: 00:11 - 15 May 2015    Post subject: Reply with quote
Cant say i have a problem looking for 37mm stanchions for my GPz. Plenty 2nd hand and new on wemoto but almost £100 each Shocked
Commuter_Tim
PostPosted: 00:27 - 15 May 2015    Post subject: Reply with quote
Well, I sense sarcasm, but it's not technically wrong as a factual statement either so Razz
PostPosted: 00:31 - 15 May 2015    Post subject: Reply with quote
Pits it stanchions? Araldite Thumbs Up
Triumph Trophy Launch Edition
dsharman1
PostPosted: 07:01 - 15 May 2015    Post subject: Reply with quote
If will get some pictures tomorrow, the rust had been removed and then araldited in them
Aprillia rs 50 2000
Honda CG 125 2001
dsharman1
PostPosted: 07:53 - 18 May 2015    Post subject: Reply with quote
Pictures are here
Aprillia rs 50 2000
Honda CG 125 2001
Robby
Dirty Old Man
PostPosted: 08:41 - 18 May 2015    Post subject: Reply with quote
That's quite bad pitting. It looks like the chrome is thin and cheap, so a second hand replacement set is likely to go the same way. I'm not sure how much of the pitting is on the swept face and how much is above it, but it does look like they're well past bodging.
Rechroming costs about the same as a pair of new budget stanchions, but gives you proper chrome that will last far longer. It depends on how long you plan on keeping the bike.
Those forks are past a cheap fix.
dsharman1
PostPosted: 10:56 - 18 May 2015    Post subject: Reply with quote
oh dear, was afraid that might be the case, i did have it on the back of a truck a while ago where then strapped the handlebars down so compressing the forks possibly further than they normally go, could this have contributed to it ?
Aprillia rs 50 2000
Honda CG 125 2001
The last post was made 11 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 70.56 Kb
