| LCK |
 LCK L Plate Warrior
 Posted: 22:27 - 15 May 2015 Post subject: Stuck break calipers. Help! |
Weaker than usual front breaks on Lexmoto Arizona, (double cylinder, + yes I know its a Chinese bike...)
I have a fair bit of mechanical confidence, so decided to remove caliper, clean pads, etc. after watching a few videos. Cylinders were well cruddy and rusty, so i gave them a scrub, pumped break gently to check movement.
One cylinder moved out a bit, the other a fair way out, but not popped out (whew..). But,.. neither of them will move or twist or anything. Tried gentle persuasion with plumbing wrench.
Am I right in thinking the next stage involves a big C clamp to push them back in? I also used very fine grade sandpaper and WD40 on the pistons only (advised by MCN tutorial), they still have a little corrosion.)
1. Do I push one cylinder, until even with other one, before clamping both and pushing back together?(I know if you push one, the other moves out.
2. Will I need to bleed the brakes/ open the valve to do this? Some say yes, (HOW THE HELL DO YOU QUICKLY OPEN AND CLOSE THE BLEED VALVE WHILE CLAMPING?) some say no in other forums. Confused.
3. Is a clamp the best way to do this?
Thanks in advance for wise words, I realise it is dangerous to fiddle with breaks if inexperienced, but thorough testing will follow on a quiet road. Gotta learn how to service them someday!  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 22:49 - 15 May 2015 Post subject: |
Take the top off your master cylinder reservoir or at least loosen it to allow air out.
The pistons should push back in by hand.
If they need more than that then it's likely that the seals are swollen or there's corrosion or dried up brake fluid in behind them.
If you're going to do it properly, the pistons and seals will have to come out and you'll need to clean behind the seals and possibly replace them. A slightly blunted dental pick is ideal for fishing them out and cleaning out the grooves - you can get them in some supermarkets. ____________________ Biking is 1/20th as dangerous as horse riding.
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 23:09 - 15 May 2015 Post subject: |
What Roger says and NEVER use any inappropriate tools, such as pliers to push the pots in or pull them out. Damaging the pots is the last thing you'd want to do.
Loosen up every single bolt, that you're gonna need to be loose later, before you take the caliper of the bracket/fork. Then use the MC to push them all out. Do it equally, put something between the pots to do so. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| RhynoCZ |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:53 - 15 May 2015 Post subject: |
Also, don't get WD40 near the rubber seals. They absorb it and expand massively, completely blocking the piston........not that I've done this  |
| Kwakki Si |
 Kwakki Si Trackday Trickster
 Posted: 11:31 - 16 May 2015 Post subject: Re: Stuck break calipers. Help! |
| LCK wrote: | Weaker than usual front breaks on Lexmoto Arizona, (double cylinder, + yes I know its a Chinese bike...)
You need to remove both pistons and split the calliper and clean it out, replace all the seals and grease up with red rubber grease and then the pistons should move nice and freely and be able to push in by hand, easy job and takes a couple of hours, plenty of youtube vids on it. ____________________ MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike! |
| kramdra |
 kramdra World Chat Champion
| LCK |
 LCK L Plate Warrior
 Posted: 15:19 - 16 May 2015 Post subject: |
Thanks for all the tips.
What worked= opened up main bleed valve, table to rest caliper on, screwdriver neck to press down pistons, topped up break fluid (in the nick of time!!)
Road test = great success, functioning brilliantly.  |
| Kwakki Si |
| LCK |
 LCK L Plate Warrior
 Posted: 18:19 - 16 May 2015 Post subject: |
The last post was made 11 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
