Stuck break calipers. Help!
LCK
PostPosted: 22:27 - 15 May 2015    Post subject: Stuck break calipers. Help! Reply with quote
Weaker than usual front breaks on Lexmoto Arizona, (double cylinder, + yes I know its a Chinese bike...)
I have a fair bit of mechanical confidence, so decided to remove caliper, clean pads, etc. after watching a few videos. Cylinders were well cruddy and rusty, so i gave them a scrub, pumped break gently to check movement.
One cylinder moved out a bit, the other a fair way out, but not popped out (whew..). But,.. neither of them will move or twist or anything. Tried gentle persuasion with plumbing wrench.
Am I right in thinking the next stage involves a big C clamp to push them back in? I also used very fine grade sandpaper and WD40 on the pistons only (advised by MCN tutorial), they still have a little corrosion.)
1. Do I push one cylinder, until even with other one, before clamping both and pushing back together?(I know if you push one, the other moves out.
2. Will I need to bleed the brakes/ open the valve to do this? Some say yes, (HOW THE HELL DO YOU QUICKLY OPEN AND CLOSE THE BLEED VALVE WHILE CLAMPING?) some say no in other forums. Confused.
3. Is a clamp the best way to do this?
Thanks in advance for wise words, I realise it is dangerous to fiddle with breaks if inexperienced, but thorough testing will follow on a quiet road. Gotta learn how to service them someday! Very Happy
PostPosted: 22:49 - 15 May 2015    Post subject: Reply with quote
Take the top off your master cylinder reservoir or at least loosen it to allow air out.
The pistons should push back in by hand.
If they need more than that then it's likely that the seals are swollen or there's corrosion or dried up brake fluid in behind them.
If you're going to do it properly, the pistons and seals will have to come out and you'll need to clean behind the seals and possibly replace them. A slightly blunted dental pick is ideal for fishing them out and cleaning out the grooves - you can get them in some supermarkets.
RhynoCZ
PostPosted: 23:09 - 15 May 2015    Post subject: Reply with quote
What Roger says and NEVER use any inappropriate tools, such as pliers to push the pots in or pull them out. Damaging the pots is the last thing you'd want to do. Thumbs Up
Loosen up every single bolt, that you're gonna need to be loose later, before you take the caliper of the bracket/fork. Then use the MC to push them all out. Do it equally, put something between the pots to do so.
DRZ4Hunned
PostPosted: 23:18 - 15 May 2015    Post subject: Reply with quote
Doing this job myself ATM, what a pain in the arse! Took the calliper off as I watched some guy on youtube do it but couldn't get mine out manually, so had to re-attach and re-bleed to try and pump them out hydraulically. Managed to get the brakes working but they'd only pump out partially, think the system may need bleeding again.
DRZ400-SM
FZS600
RhynoCZ
PostPosted: 23:35 - 15 May 2015    Post subject: Reply with quote
Yep, always use your brain before you use your tools. Thumbs Up
Pigeon
PostPosted: 23:53 - 15 May 2015    Post subject: Reply with quote
Also, don't get WD40 near the rubber seals. They absorb it and expand massively, completely blocking the piston........not that I've done this Whistle
Kwakki Si
PostPosted: 11:31 - 16 May 2015    Post subject: Re: Stuck break calipers. Help! Reply with quote
You need to remove both pistons and split the calliper and clean it out, replace all the seals and grease up with red rubber grease and then the pistons should move nice and freely and be able to push in by hand, easy job and takes a couple of hours, plenty of youtube vids on it.
MOD1 passed 26/01/12... MOD2 passed 08/02/12
My current ride: ZX6R NINJA G2, The GREEEEN one!
Is it a bird? Is it a plane? No, it's a mother fucking motorbike!
kramdra
PostPosted: 14:05 - 16 May 2015    Post subject: Re: Stuck break calipers. Help! Reply with quote
LCK wrote:
...Tried gentle persuasion with plumbing wrench.
1) good way to ruin pistons
2) no. only spotless, clean pistons can be pushed in unless you want to ruin seals.
3) very fine abraisives ~1500grit can be used too polish stainless pistons, but not with calliper assembled.
pop the pistons out, clean them, clean the seals in fresh brake fluid, clean the seal groves. Check the seals for any damage, if so replace. reassemble.
Bleeding takes about 5 mins, reverse fill with a syringe, crack open the MC banjo to bleed.
LCK
PostPosted: 15:19 - 16 May 2015    Post subject: Reply with quote
Thanks for all the tips.
What worked= opened up main bleed valve, table to rest caliper on, screwdriver neck to press down pistons, topped up break fluid (in the nick of time!!)
Road test = great success, functioning brilliantly. Thumbs Up Thumbs Up Thumbs Up Mr. Green
Kwakki Si
PostPosted: 16:53 - 16 May 2015    Post subject: Reply with quote
Why not just give them a overhaul anyways? god knows what condition the seals are in.
LCK
PostPosted: 18:19 - 16 May 2015    Post subject: Reply with quote
It is my BF's bike, if he wants to strip them he can Smile
The last post was made 11 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 74.27 Kb
