| Medicinal_Motocross |
 Medicinal_Motocross Nova Slayer
 Posted: 21:51 - 14 May 2015 Post subject: Bike problems |
Looking to get some advice on my kmx 125 issues firstly i re packed my silencer today with fine hair like wool from eBay replacing the stuff that was in there which was of a different complexion was almost like it came in a sheet similar to air filter sheet/foam but in a yellow colour, the stuff i used was very fine.. Have attached a picture of it
2) I fitted a new front caliper piston and seals and cant bleed it for the life of me, the hose isnt blocked, fluid is coming out of the end of bleed nipple althought i did see a bit of rust on one of the threads inside the caliper i cant see this being the problem but i may be wrong am not a mechanic. Can anyone advise what could be the cause? I fitted new pads correctly and pushed the piston in fully upon fitting
3) I ran it for 10-20 minutes earlier as i need to run it in just ticking over no load on it when i turned the engine off and touched the clutch cover, flywheel cover it was cold but i touched the barrel & kips powervalve cover it was very hot, it does have a liner fitted but what could be the cause of this?
Im aware the liners are no where near as good for heat transfer etc but im sure it shouldnt be that hot, It was chucking out some smoke from the tail can but after a while seemed to be clear and not much at all (had this problem the other day) should smoke be coming out all the time its running?
I know it does/did when i rev a bit of pull off, i did bleed the oil pump if i took the carb off, turned throttle will 2stroke oil come through the valve in inlet manifold rubber no matter what if its coming through as it should? I did fit green oil hose which i think has a smaller internal diameter. Im just slightly concerned being a 2t. It has a DEP end can fitted and standard(As far as i know) expansion chamber but running 102.5 jet same as standard which
i did before took it off the road for a rebuild, could this have anything to do with it?
4) The bike failed a mot as it seemed the headlight and brake light was "flashing" with the indicators, it doesnt struggle to power the indicators alone with engine running but if i put headlight on with indicators it struggles but does work if i rev?  |
| Just_James |
 Just_James Could Be A Chat Bot
| doggone |
 doggone World Chat Champion
 Posted: 07:57 - 15 May 2015 Post subject: .. |
So the fact the barrel was stupidly hot isn't a major problem? Also noticed on one side of the barrel at the base gasket it is leaking some 2t from what I can see a tiny amount but I noticed it, gona have try tighten the cylinder nuts. I'm gona have to replace the pipe from pump to inlet just so I know its feeding& will add a bit of 2t into the tank.
If I'm not mistaken I only saw one earth when attaching the loom and that goes onto a bracket on the frame with a bolt to secure, if I move the front part of the loom up and down the headlight will sometimes go off almost like a loose wire, the last thing I need is to be stripping the loom. Does this sound like a earth or a loose wire? Like I said I only noticed one earth and that's secured, isn't all that clear in the Haynes diagram ?  |
| doggone |
| Robby |
 Robby Dirty Old Man
 Posted: 08:52 - 18 May 2015 Post subject: |
You seem to have a few problems there. Break for walls of text up into sentences a bit and use the spell check.
1. Front brake. I assume you've had the whole system drained. Refilling it takes a while, you need to get enough fluid in to fill the caliper through a master cylinder that only passes about 0.5cc of fluid with each stroke. Sit there and pump the lever for about 10 minutes and it'll firm up. Then walk off and have a cup of tea, then come back to it and bleed it. Air has to move up to the master cylinder from the caliper, this happens slowly.
2. Electrical fault. There is likely to be more than one earth, have a look at a wiring diagram to find them, or work out which colour wire is earth (green on Honda) and trace those wires until they meet the frame. Earth connections corrode over time, you will need to sand this corrosion off to get a good connection.
3. Heat. It is normal for the cylinder and head to get hot while the cases stay cool. The cylinder is where the heat is made, and where the cooling system runs.
4. Weeping gasket. Did you, or someone that is not an expert, rebuild the engine? If the engine was rebuilt without the gasket faces being scraped perfectly clean, then the new gasket will fail. You can't bodge it with sealant, if a gasket is leaking then you need to dismantle, clean the faces, and fit a new gasket. |
| P.addy |
 P.addy Red Rocket
| MCN. |
 MCN. Banned
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful? |
