EXUP valve bushes
CBRMAN94
PostPosted: 19:55 - 16 May 2015    Post subject: EXUP valve bushes Reply with quote
So... Yamaha FZR400RR
Anyone know where i can get some bushes measuring ID 10mm x OD 17mm x 7mm made (Preferably Brass or something similar)?
Either mail order or North East Smile
I need 2 making but the bushes from Yamaha are typical OEM prices and i'd rather try somewhere else first...
Anyone else been had any experiences with EXUP bushes remove and install too?
Cheers Thumbs Up
Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR
FirebladeRuss
PostPosted: 16:44 - 19 May 2015    Post subject: Reply with quote
I's bronze you want mate, not brass.
And sorry, no idea.
Twitter is for people who can't STFU even when they're by themselves
Fizzer Thou
PostPosted: 17:25 - 19 May 2015    Post subject: Reply with quote
Crikey!!!
Those parts are expensive for what they are Shocked
https://www.cmsnl.com/yamaha-fzr400sac-1990_model9586/partslist/B-07.html#results
But when I needed some I made my ones from phospher-bronze.
But my ones were for my Exup 1000 so I am not sure what size you might need.If you measure up the outside diameter of the shaft it may well be that they are the same size as for the 1000.
Have a look on www.exup1000.co.uk and www.fzr1000.co.uk for more help and information Thumbs Up
When I serviced the valve on my R1 there was a plate on the far side of the vane housing which could be removed so as to drift out the worn bush
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/20100425_3-1.jpg
On my Exup1000 the hole is blind so is almost impossible to remove that bush.I ended up drilling a hole and using a blanking screw to seal it after I had replaced the bush Thumbs Up
Always have a 'Plan B'
PostPosted: 19:25 - 19 May 2015    Post subject: Reply with quote
Only one I made was from silver steel. No point using yellow metal in that environment I think, there's nothing to lubricate. I'd choose hard over self-lubricating.
CBRMAN94
PostPosted: 20:58 - 19 May 2015    Post subject: Reply with quote
Blanked off on one side :/ Can see i'm gonna have to fork out for some OEM ones at some point just to make sure they're right and seeing as it's a PITA to replace them too. I might leave it until next time it's off the road and add it to the list, Can put up with the little rattle for a while i suppose.
Bit of a bad design from Yamaha. Still, every bike has bad design features ehh?
EDIT: looking at your photo, i think the bush came out on the valve, Is that photo with the bush removed?
The last post was made 11 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 45.87 Kb
