Tyres
benevs1995
PostPosted: 04:18 - 23 May 2015    Post subject: Tyres Reply with quote
Just wondering could I put thinker tyres on my Honda Cb125f (2015)
Standard tyre sizes- Front: 80/100/18 Rear: 90/90/18
Thanks all! Thumbs Up
B.Evans
garth
PostPosted: 07:50 - 23 May 2015    Post subject: Reply with quote
I thick that's the thinkest you can go.
Taught2BCauti...
PostPosted: 07:56 - 23 May 2015    Post subject: Reply with quote
Do you mean thinker, or winder?
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
garth
PostPosted: 08:18 - 23 May 2015    Post subject: Reply with quote
I thick I now the different between winder and thinker. Rolling Eyes
PostPosted: 08:42 - 23 May 2015    Post subject: Reply with quote
I thick if you winted winder tires yuo shoold harv gotta biggar byke.
Andy_Pagin
PostPosted: 09:17 - 23 May 2015    Post subject: Reply with quote
At the risk of wrecking this thread with a serious answer, why fit wider tyres? You'll still only have the same amount of rubber in contact with the road, possibly less since bigger tyres are designed to squidge into the tarmac with a lot more weight pressing down on them.
talkToTheHat
PostPosted: 00:17 - 30 May 2015    Post subject: Reply with quote
narrower tyres let you turn in faster, broad tyres turn in slowly.
Kickstand eliminators are not a performance advantage.
For a given weight and tyre pressure, the contact patch will stay constant, so a wider tyre will deform less and harder to get up to temperature. Why fat tyres on a race bike then? Because in race conditions managing the heat dissipation through the tyres is an issue.
Furthermore, the higher the ground pressure and smaller the contact patch the smaller the risk of aquaplaning in the wet.
This changes on loose surfaces where low ground pressure and a tread pattern that digs into the surface over a large area is advantageous.
Bandit. does. everything.
PostPosted: 09:31 - 30 May 2015    Post subject: Reply with quote
<Idea>They should run vented tyres.</Idea>
The last post was made 11 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2 - MySQL Queries: 13 - Page Size: 56.86 Kb
