| lincsrider |
 lincsrider Two Stroke Sniffer
 Posted: 22:00 - 24 May 2015 Post subject: YBR--toasted engine? |
So, I was riding my 06 YBR (carbed version) down an A-road for around 30 min, hit 60 mph in 4th, shifted up into 5th, when I heard the noise of something internal obviously falling apart, followed by a complete loss of power. When I tried to start her up again, I was met with an ominous clanking sound--though it did pull for a few feet before the power cut again. Further attempts at starting just lead to more horrible mechanical noises--now all I get is a 'click' when I try the starter.
There was smoke pouring out of the dipstick hole when I checked the oil level, so I suppose it had catastrophically overheated. In truth, the bike never sounded 'right' ever since I adjusted the valves and took the engine cover off to clean the oil strainer. Also, earlier that day, I did have difficulty changing gears, having to press quite hard on the gear lever--but I adjusted the clutch cable and assumed all was well.
I'm fearing the worst TBH; but I could really do with some sympathetic advice from someone who isn't mechanically clueless, as I am.  |
| SQL |
 SQL World Chat Champion
 Posted: 22:09 - 24 May 2015 Post subject: |
| lincsrider |
 Posted: 22:24 - 24 May 2015 Post subject: |
Yeah, I suspected as much.
But if the engine blew after only 33k on the clock I won't bother spending a small fortune on a replacement (+ labour costs.) I'm just annoyed that I've wasted £1400 on a piece of Chinese crap that only ran for 6 months.
Still, on the plus side, I'll get nice and fit cycling to work over the next few weeks. |
| SQL |
| lincsrider |
| Northern Monkey |
 Northern Monkey World Chat Champion
| lincsrider |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 19:28 - 25 May 2015 Post subject: Re: YBR--toasted engine? |
| lincsrider wrote: | In truth, the bike never sounded 'right' ever since I adjusted the valves and took the engine cover off to clean the oil strainer.
If I'd adjusted valves on a bike and instantly noticed it didn't sound right, I'd have re-checked them. Particularly as it's 10min job.
And if they were ok, worked backwards through the things done prior to noticing an issue.
| Quote: |
Could have been oil starvation. Having cleaned the strainer and put oil back in, were you definitely sure the level was right. Also, did you remove the oil bleed bolt at the top of the exhaust port to make sure the oil was circulating?
Doesn't really help you.
Could be mashed valves. Could be a seized engine. Might have blown a hole in the piston (unlikely) and you could do a compression test. But it sounds like the engine isn't even turning over (ie seized), so pointless to do compression test.
Put it on centre stand, bung it in 4th gear and rotate rear wheel by hand if you can. If you can't, then you might as well whip the head off for giggles as it's only going to take 15mins. |
| Carvel |
 Carvel World Chat Champion
| lincsrider |
 Posted: 07:25 - 26 May 2015 Post subject: Re: YBR--toasted engine? |
| Pigeon wrote: |
The valves sounded off to me compared to other bikes I've owned, but the clearances were definitely within the specified range (they were too tight before.)
| Quote: |
Yeah, the oil was at the correct level--but I didn't check the bleed bolt.
Anyway, after a little inspection this morning, the top end of the engine looks okay; and it does seem to turn over as it should, as I can hear and feel compression through the spark plug hole as I move the rear wheel. But the bike refuses to start--the starter motor either clicks or whirls a bit (depending on the compression stroke); and after several more attempts at bump starting, the best I got was a half-chug.
So I'm at a loss. Would a transmission or gearbox problem prevent the bike from firing up? Or would the clattering\clanking sound I heard before the power loss suggest a temporary seizure? |
| Northern Monkey |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 10:42 - 26 May 2015 Post subject: Re: YBR--toasted engine? |
| lincsrider wrote: | Also, earlier that day, I did have difficulty changing gears, having to press quite hard on the gear lever--but I adjusted the clutch cable and assumed all was well. |
I think the oil pump failed, not lubing the gearbox caused the difficulties with gear changes and I also think the head was running completely dry and that's why it potatoed itself.
Drain the oil and check for bits of metal.
Overheating is out of question, it was designed to work at 30°C+ and slowly moving traffic.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| lincsrider |
| RhynoCZ |
 Posted: 13:02 - 26 May 2015 Post subject: |
Well, oil reduces friction, friction generates heat, no oil means no reduction of the friction and you get yourself a heat generator.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
| Northern Monkey |
| Ed Case |
 Ed Case World Chat Champion
The last post was made 11 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
